[postgis-users] PostGIS Trigger doesn't work
Marcello Benigno
benigno.marcello at gmail.com
Mon Jan 28 10:07:09 PST 2013
Hi Half,
The trigger worked with your help (NEW.the_geom), thank you!!!
However there is something intriguing... when I deleted all the records
from the pipeline table and inserted the first record, It's not works (the
field was empty), the field of trigger that should be filled, works only
from the second record and everything works fine after that, interesting
isn't?
Cheers,
*Marcello Benigno B. de Barros Filho*
Prof. do Curso Superior de Tecnologia em Geoprocessamento - IFPB
Mestre em Ciências Geodésicas e Tecnologias da Geoinformação - UFPE
Doutorando em Tecnologia Ambiental e Recursos Hídricos - UFPE
http://profmarcello.blogspot.com
http://about.me/marcello.benigno
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130128/11de232a/attachment.html>
