[postgis-users] OpenBSd installation problem
Bborie Park
dustymugs at gmail.com
Mon Jul 1 13:19:52 PDT 2013
Marcelo,
Those missing symbols are all from PostgreSQL. You'll want to make
sure the PostgreSQL libs and dev files are provided.
-bborie
On Mon, Jul 1, 2013 at 1:17 PM, Marcelo Bacha <dronsz at gmail.com> wrote:
> Hi,
> This is my first posting, I´m new to Postgis. I´ve seen similar problems
> related in lists all around, but this one, I couldn´t manage to solve.
> I have an OpenBSD 5.3 server, with PostgreSQL 9.2.4 on it, which always
> worked fine. I have to transfer some geospatial databases from a Windows
> server, so I downloaded Postgis from the source (I needed the latest
> versions), configured, compiled & installed it.
> Everything seems to be fine, but when I try to create the postgis extension
> (with raster support) on psql:
> postgres=# CREATE EXTENSION postgis;
> ERROR: could not load library "/usr/local/pgsql/lib/rtpostgis-2.2.so":
> dlopen (/usr/local/pgsql/lib/rtpostgis-2.2.so) failed: Cannot load specified
> object
> The paths seems all to be OK:
> # ls -l /usr/local/pgsql/lib/*post*
> -rwxr-xr-x 1 root wheel 1276039 Jul 1 16:50
> /usr/local/pgsql/lib/postgis-2.2.so
> -rwxr-xr-x 1 root wheel 1208861 Jul 1 16:50
> (I know it´s the development, and not the stable release, but the results
> are the same with all other releases.)
> When I try to preload the rtpostgis shared object setting the LD_PRELOAD
> environment variable, I get this on psql:
> $ psql
> psql:/usr/local/pgsql/lib/rtpostgis-2.2.so: undefined symbol
> 'CurrentMemoryContext'
> 'SPI_tuptable'
> psql:/usr/local/pgsql/lib/rtpostgis-2.2.so: undefined symbol 'SPI_result'
> 'InterruptPending'
> 'SPI_processed'
> psql (9.2.4)
> Didn´t find any further useful info setting LD_DEBUG (I may list the output
> if necessary, anyway).
> Any hint on how to solve this? I´m running out of ideas.
> Thanks in advance,
> Marcelo
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
