[postgis-users] postgres and postgis upgrade
Marcos Cano mcano at stsa.info
Thu Jul 4 07:07:49 PDT 2013
what version of pg_dump should i use?... i tried the 8..3.2 and i think it
works, but trying the suggested one, wich is the latest (9.2.4) seems just
to not work properly because it does not dump my entire database (i assume
is because of the mismatch of postgis versions)
On Wed, Jul 3, 2013 at 12:00 PM, Paragon Corporation <lr at pcorp.us> wrote:
> Yes (custom dump of 8.3.2 + pgis, create new postgis 2.0.4 in 9.2.4 and
> restore backup) is the recommended way.  9.2.4 + 1.5.8 are borderline
> compatible so I would avoid that mix and if your ultimate goal is to go to
> 2.0, 1.5.8 requires a hard upgrade anyway so not worth the hassle.
> *From:* postgis-users-bounces at lists.osgeo.org [mailto:
> postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Marcos Cano
> *Sent:* Wednesday, July 03, 2013 10:43 AM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* [postgis-users] postgres and postgis upgrade
>  So I'm trying to upgrade Postgres and postgis.. My current versions are
> 8.3.2 and 1.3 respectively. And trying to upgrade to postgis 2.0.4 and
> Postgres 9.2.4
> I've been trying a lot of options like:hard upgrade of postgis to 1.5.8 in
> the Postgres 8.3 ( as I'm sure that version of postgis is compatible with
> Postgres 8.3 and 9.2.4)
> Then installing postgres 9.2.4 + postgis 1.5.8 and do a pg_upgrade and
> finally do a hard upgrade of postgis to 2.0.4 in the postgres 9.2.4
> installation. It  seems to work until an error happened during the
> pg_upgrade
> Your installation contains the "name" data type in user tables.  This data
> type changed its internal alignment between your old and new  clusters so
> this cluster cannot currently be upgraded.  You can remove the problem
> tables and restart the upgrade.
> So I tried another option but I don't know if this will work. Here's my
> idea:
> Do a custom dump of the DB in Postgres 8.3.2 + pgis 1.3 .
> Install 9.2.4 with postgis 2.0.4
> And do a restore with perl script included in the postgis binary folder
> (perl utils/postgis_restore.pl)
> do you think it will work?
> postgis-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130704/bca03a4c/attachment.html>
