[postgis-users] postgres and postgis upgrade
Racine, Sylvain syracine at sympatico.ca
Thu Jul 4 08:51:28 PDT 2013
You have to use pg_dump version 8.3.2 to backup your database,e.g. the
same version of your source database. To restore, use the Perl script
and postgis.sql given with  Postgis 2.0.4. This script calls pg_dump
command. It must be pg_dump version 9.2.4, e.g. your destination
database version. Use "pg_dump --version" to know the version of your
command.
You seem use 2 differents versions of PostgreSQL and PostGIS on the same
computer. To get a particular version of a command, type the whole path
of the command.
Regard
Sylvain Racine
Le 2013-07-04 10:07, Marcos Cano a écrit :
> what version of pg_dump should i use?... i tried the 8..3.2 and i
> think it works, but trying the suggested one, wich is the latest
> (9.2.4) seems just to not work properly because it does not dump my
> entire database (i assume is because of the mismatch of postgis versions)
> On Wed, Jul 3, 2013 at 12:00 PM, Paragon Corporation <lr at pcorp.us
> <mailto:lr at pcorp.us>> wrote:
>     Yes (custom dump of 8.3.2 + pgis, create new postgis 2.0.4 in
>     9.2.4 and restore backup) is the recommended way.  9.2.4 + 1.5.8
>     are borderline compatible so I would avoid that mix and if your
>     ultimate goal is to go to 2.0, 1.5.8 requires a hard upgrade
>     anyway so not worth the hassle.
>     *From:* postgis-users-bounces at lists.osgeo.org
>     <mailto:postgis-users-bounces at lists.osgeo.org>
>     [mailto:postgis-users-bounces at lists.osgeo.org
>     <mailto:postgis-users-bounces at lists.osgeo.org>] *On Behalf Of
>     *Marcos Cano
>     *Sent:* Wednesday, July 03, 2013 10:43 AM
>     *To:* postgis-users at lists.osgeo.org
>     <mailto:postgis-users at lists.osgeo.org>
>     *Subject:* [postgis-users] postgres and postgis upgrade
>     So I'm trying to upgrade Postgres and postgis.. My current
>     versions are 8.3.2 and 1.3 respectively. And trying to upgrade to
>     postgis 2.0.4 and Postgres 9.2.4
>     I've been trying a lot of options like:hard upgrade of postgis to
>     1.5.8 in the Postgres 8.3 ( as I'm sure that version of postgis is
>     compatible with Postgres 8.3 and 9.2.4)
>     Then installing postgres 9.2.4 + postgis 1.5.8 and do a pg_upgrade
>     and finally do a hard upgrade of postgis to 2.0.4 in the postgres
>     9.2.4 installation. It  seems to work until an error happened
>     during the pg_upgrade
>     Your installation contains the "name" data type in user tables.
>      This data type changed its internal alignment between your old
>     and new  clusters so this cluster cannot currently be upgraded.
>      You can remove the problem tables and restart the upgrade.
>     So I tried another option but I don't know if this will work.
>     Here's my idea:
>     Do a custom dump of the DB in Postgres 8.3.2 + pgis 1.3 .
>     Install 9.2.4 with postgis 2.0.4
>     And do a restore with perl script included in the postgis binary
>     folder  (perl utils/postgis_restore.pl <http://postgis_restore.pl>)
>     do you think it will work?
>     _______________________________________________
>     postgis-users mailing list
>     postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
>     http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130704/22c10b80/attachment.html>
