[postgis-users] postgres and postgis upgrade
Racine, Sylvain syracine at sympatico.ca
Thu Jul 4 15:07:32 PDT 2013
The postgis.sql is a part of the restore process. Because you'll make
hard upgrade of PostGIS, you have to use Perl script postgis_restore.pl.
This script removes old PostGIS functions from your backup and installs
the new ones in the new database. Then, you have to give the path of
postgis.sql (or lwpostgis.sql) when you call postgis_restore.pl on
command line.
I'm not really fan of the new procedure using "CREATE EXTENSION
postgis". It's an automatic process enabled in PostgreSQL 9.1 and more.
With this procedure, you have to use PostGIS who is embedded with
PostgreSQL package. I encountered earlier some errors when I tried to
install PostGIS using this procedure on a Windows box. But, using the
old procedure I described above, I had the complete control of the
installation and I always got a functionnal database, even with
PostgreSQL 9.2.
Regard
Sylvain Racine
Le 2013-07-04 13:06, Marcos Cano a écrit :
> well i guess while installing and making the postgis i installed it
> against the 9.2.4  (with this : "./configure
> --with-pgconfig=/usr/local/pgsql9.2.4/bin/pg_config" )
> the postgis.sql you mention is to create a spatially enabled database?
> or is it part of the restore process?
> and yes im using the full path to the command to do everything.
> thank you very much i really appreciate it
> On Thu, Jul 4, 2013 at 9:51 AM, Racine, Sylvain <syracine at sympatico.ca
> <mailto:syracine at sympatico.ca>> wrote:
>     You have to use pg_dump version 8.3.2 to backup your database,e.g.
>     the same version of your source database. To restore, use the Perl
>     script and postgis.sql given with  Postgis 2.0.4. This script
>     calls pg_dump command. It must be pg_dump version 9.2.4, e.g. your
>     destination database version. Use "pg_dump --version" to know the
>     version of your command.
>     You seem use 2 differents versions of PostgreSQL and PostGIS on
>     the same computer. To get a particular version of a command, type
>     the whole path of the command.
>     Regard
>     Sylvain Racine
>     Le 2013-07-04 10:07, Marcos Cano a écrit :
>>     what version of pg_dump should i use?... i tried the 8..3.2 and i
>>     think it works, but trying the suggested one, wich is the latest
>>     (9.2.4) seems just to not work properly because it does not dump
>>     my entire database (i assume is because of the mismatch of
>>     postgis versions)
>>     On Wed, Jul 3, 2013 at 12:00 PM, Paragon Corporation <lr at pcorp.us
>>     <mailto:lr at pcorp.us>> wrote:
>>         Yes (custom dump of 8.3.2 + pgis, create new postgis 2.0.4 in
>>         9.2.4 and restore backup) is the recommended way.  9.2.4 +
>>         1.5.8 are borderline compatible so I would avoid that mix and
>>         if your ultimate goal is to go to 2.0, 1.5.8 requires a hard
>>         upgrade anyway so not worth the hassle.
>>         *From:* postgis-users-bounces at lists.osgeo.org
>>         <mailto:postgis-users-bounces at lists.osgeo.org>
>>         [mailto:postgis-users-bounces at lists.osgeo.org
>>         <mailto:postgis-users-bounces at lists.osgeo.org>] *On Behalf Of
>>         *Marcos Cano
>>         *Sent:* Wednesday, July 03, 2013 10:43 AM
>>         *To:* postgis-users at lists.osgeo.org
>>         <mailto:postgis-users at lists.osgeo.org>
>>         *Subject:* [postgis-users] postgres and postgis upgrade
>>         So I'm trying to upgrade Postgres and postgis.. My current
>>         versions are 8.3.2 and 1.3 respectively. And trying to
>>         upgrade to postgis 2.0.4 and Postgres 9.2.4
>>         I've been trying a lot of options like:hard upgrade of
>>         postgis to 1.5.8 in the Postgres 8.3 ( as I'm sure that
>>         version of postgis is compatible with Postgres 8.3 and 9.2.4)
>>         Then installing postgres 9.2.4 + postgis 1.5.8 and do a
>>         pg_upgrade and finally do a hard upgrade of postgis to 2.0.4
>>         in the postgres 9.2.4 installation. It  seems to work until
>>         an error happened during the pg_upgrade
>>         Your installation contains the "name" data type in user
>>         tables.  This data type changed its internal alignment
>>         between your old and new clusters so this cluster cannot
>>         currently be upgraded.  You can remove the problem tables and
>>         restart the upgrade.
>>         So I tried another option but I don't know if this will work.
>>         Here's my idea:
>>         Do a custom dump of the DB in Postgres 8.3.2 + pgis 1.3 .
>>         Install 9.2.4 with postgis 2.0.4
>>         And do a restore with perl script included in the postgis
>>         binary folder  (perl utils/postgis_restore.pl
>>         <http://postgis_restore.pl>)
>>         do you think it will work?
>>         _______________________________________________
>>         postgis-users mailing list
>>         http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>     postgis-users at lists.osgeo.org  <mailto:postgis-users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130704/438988db/attachment.html>
