[postgis-users] postgres and postgis upgrade
Marcos Cano
mcano at stsa.info
Fri Jul 5 08:41:49 PDT 2013
so when running my script everything went well except that when i run
"psql --version" it still runs the 8.3.2 version... so to do psql (9.2.4) i
have to indicate the full path to pgsql9.2.4/bin/psql ..
any idea on how to fix this?
On Thu, Jul 4, 2013 at 4:07 PM, Racine, Sylvain <syracine at sympatico.ca>wrote:
> The postgis.sql is a part of the restore process. Because you'll make
> hard upgrade of PostGIS, you have to use Perl script postgis_restore.pl.
> This script removes old PostGIS functions from your backup and installs the
> new ones in the new database. Then, you have to give the path of
> postgis.sql (or lwpostgis.sql) when you call postgis_restore.pl on
> command line.
> I'm not really fan of the new procedure using "CREATE EXTENSION postgis".
> It's an automatic process enabled in PostgreSQL 9.1 and more. With this
> procedure, you have to use PostGIS who is embedded with PostgreSQL package.
> I encountered earlier some errors when I tried to install PostGIS using
> this procedure on a Windows box. But, using the old procedure I described
> above, I had the complete control of the installation and I always got a
> functionnal database, even with PostgreSQL 9.2.
> Regard
> Sylvain Racine
> Le 2013-07-04 13:06, Marcos Cano a écrit :
> well i guess while installing and making the postgis i installed it
> against the 9.2.4 (with this : "./configure
> --with-pgconfig=/usr/local/pgsql9.2.4/bin/pg_config" )
> the postgis.sql you mention is to create a spatially enabled database? or
> is it part of the restore process?
> and yes im using the full path to the command to do everything.
> thank you very much i really appreciate it
> On Thu, Jul 4, 2013 at 9:51 AM, Racine, Sylvain <syracine at sympatico.ca>wrote:
>> You have to use pg_dump version 8.3.2 to backup your database,e.g. the
>> same version of your source database. To restore, use the Perl script and
>> postgis.sql given with Postgis 2.0.4. This script calls pg_dump command.
>> It must be pg_dump version 9.2.4, e.g. your destination database version.
>> Use "pg_dump --version" to know the version of your command.
>> You seem use 2 differents versions of PostgreSQL and PostGIS on the same
>> computer. To get a particular version of a command, type the whole path of
>> the command.
>> Regard
>> Sylvain Racine
>> Le 2013-07-04 10:07, Marcos Cano a écrit :
>> what version of pg_dump should i use?... i tried the 8..3.2 and i think
>> it works, but trying the suggested one, wich is the latest (9.2.4) seems
>> just to not work properly because it does not dump my entire database (i
>> assume is because of the mismatch of postgis versions)
>> On Wed, Jul 3, 2013 at 12:00 PM, Paragon Corporation <lr at pcorp.us> wrote:
>>> Yes (custom dump of 8.3.2 + pgis, create new postgis 2.0.4 in 9.2.4
>>> and restore backup) is the recommended way. 9.2.4 + 1.5.8 are borderline
>>> compatible so I would avoid that mix and if your ultimate goal is to go to
>>> 2.0, 1.5.8 requires a hard upgrade anyway so not worth the hassle.
>>> *From:* postgis-users-bounces at lists.osgeo.org [mailto:
>>> postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Marcos Cano
>>> *Sent:* Wednesday, July 03, 2013 10:43 AM
>>> *To:* postgis-users at lists.osgeo.org
>>> *Subject:* [postgis-users] postgres and postgis upgrade
>>> So I'm trying to upgrade Postgres and postgis.. My current versions
>>> are 8.3.2 and 1.3 respectively. And trying to upgrade to postgis 2.0.4 and
>>> Postgres 9.2.4
>>> I've been trying a lot of options like:hard upgrade of postgis to
>>> 1.5.8 in the Postgres 8.3 ( as I'm sure that version of postgis is
>>> compatible with Postgres 8.3 and 9.2.4)
>>> Then installing postgres 9.2.4 + postgis 1.5.8 and do a pg_upgrade and
>>> finally do a hard upgrade of postgis to 2.0.4 in the postgres 9.2.4
>>> installation. It seems to work until an error happened during the
>>> pg_upgrade
>>> Your installation contains the "name" data type in user tables. This
>>> data type changed its internal alignment between your old and new clusters
>>> so this cluster cannot currently be upgraded. You can remove the problem
>>> tables and restart the upgrade.
>>> So I tried another option but I don't know if this will work. Here's
>>> my idea:
>>> Do a custom dump of the DB in Postgres 8.3.2 + pgis 1.3 .
>>> Install 9.2.4 with postgis 2.0.4
>>> And do a restore with perl script included in the postgis binary folder
>>> (perl utils/postgis_restore.pl)
>>> do you think it will work?
>>> postgis-users mailing list
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>> postgis-users mailing listpostgis-users at lists.osgeo.orghttp://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130705/5e6fab04/attachment.html>
