[postgis-users] postgres and postgis upgrade
Marcos Cano mcano at stsa.info
Mon Jul 8 13:25:45 PDT 2013
ubuntu server 12.04... and when i do "echo $PATH" the environment variable
is blank
On Mon, Jul 8, 2013 at 9:12 AM, Racine, Sylvain <syracine at sympatico.ca>wrote:
>  Sorry for the delay. It was the week end. So I closed the computer. To
> disable psql command for 8.3.2 version, you have to remove the whole path
> of your old PostgreSQL installation from you PATH variable and replace it
> by the new one. Depending of the type of OS you use, ex. on Linux, type
> "echo PATH" to see the paths associated to your system or on Windows, type
> just "PATH" to see the paths.
> If you need any help to remove the PostgreSQL 8.3.2 version from PATH
> variable, please indicate the type of OS you use.
> Regard
> Sylvain Racine
> Le 2013-07-05 11:41, Marcos Cano a écrit :
>  so when running my script everything went well except that when i run
> "psql --version" it still runs the 8.3.2 version... so to do psql (9.2.4) i
> have to indicate the full path to pgsql9.2.4/bin/psql ..
>  any idea on how to fix this?
> On Thu, Jul 4, 2013 at 4:07 PM, Racine, Sylvain <syracine at sympatico.ca>wrote:
>>  The postgis.sql is a part of the restore process. Because you'll make
>> hard upgrade of PostGIS, you have to use Perl script postgis_restore.pl.
>> This script removes old PostGIS functions from your backup and installs the
>> new ones in the new database. Then, you have to give the path of
>> postgis.sql (or lwpostgis.sql) when you call postgis_restore.pl on
>> command line.
>> I'm not really fan of the new procedure using "CREATE EXTENSION postgis".
>> It's an automatic process enabled in PostgreSQL 9.1 and more. With this
>> procedure, you have to use PostGIS who is embedded with PostgreSQL package.
>> I encountered earlier some errors when I tried to install PostGIS using
>> this procedure on a Windows box. But, using the old procedure I described
>> above, I had the complete control of the installation and I always got a
>> functionnal database, even with PostgreSQL 9.2.
>> Regard
>> Sylvain Racine
>> Le 2013-07-04 13:06, Marcos Cano a écrit :
>> well i guess while installing and making the postgis i installed it
>> against the 9.2.4  (with this : "./configure
>> --with-pgconfig=/usr/local/pgsql9.2.4/bin/pg_config" )
>> the postgis.sql you mention is to create a spatially enabled database? or
>> is it part of the restore process?
>>  and yes im using the full path to the command to do everything.
>>  thank you very much i really appreciate it
>> On Thu, Jul 4, 2013 at 9:51 AM, Racine, Sylvain <syracine at sympatico.ca>wrote:
>>>  You have to use pg_dump version 8.3.2 to backup your database,e.g. the
>>> same version of your source database. To restore, use the Perl script and
>>> postgis.sql given with  Postgis 2.0.4. This script calls pg_dump command.
>>> It must be pg_dump version 9.2.4, e.g. your destination database version.
>>> Use "pg_dump --version" to know the version of your command.
>>> You seem use 2 differents versions of PostgreSQL and PostGIS on the same
>>> computer. To get a particular version of a command, type the whole path of
>>> the command.
>>> Regard
>>> Sylvain Racine
>>> Le 2013-07-04 10:07, Marcos Cano a écrit :
>>> what version of pg_dump should i use?... i tried the 8..3.2 and i think
>>> it works, but trying the suggested one, wich is the latest (9.2.4) seems
>>> just to not work properly because it does not dump my entire database (i
>>> assume is because of the mismatch of postgis versions)
>>> On Wed, Jul 3, 2013 at 12:00 PM, Paragon Corporation <lr at pcorp.us>wrote:
>>>>  Yes (custom dump of 8.3.2 + pgis, create new postgis 2.0.4 in 9.2.4
>>>> and restore backup) is the recommended way.  9.2.4 + 1.5.8 are borderline
>>>> compatible so I would avoid that mix and if your ultimate goal is to go to
>>>> 2.0, 1.5.8 requires a hard upgrade anyway so not worth the hassle.
>>>> *From:* postgis-users-bounces at lists.osgeo.org [mailto:
>>>> postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Marcos Cano
>>>> *Sent:* Wednesday, July 03, 2013 10:43 AM
>>>> *To:* postgis-users at lists.osgeo.org
>>>> *Subject:* [postgis-users] postgres and postgis upgrade
>>>>   So I'm trying to upgrade Postgres and postgis.. My current versions
>>>> are 8.3.2 and 1.3 respectively. And trying to upgrade to postgis 2.0.4 and
>>>> Postgres 9.2.4
>>>>  I've been trying a lot of options like:hard upgrade of postgis to
>>>> 1.5.8 in the Postgres 8.3 ( as I'm sure that version of postgis is
>>>> compatible with Postgres 8.3 and 9.2.4)
>>>> Then installing postgres 9.2.4 + postgis 1.5.8 and do a pg_upgrade and
>>>> finally do a hard upgrade of postgis to 2.0.4 in the postgres 9.2.4
>>>> installation. It  seems to work until an error happened during the
>>>> pg_upgrade
>>>> Your installation contains the "name" data type in user tables.  This
>>>> data type changed its internal alignment between your old and new  clusters
>>>> so this cluster cannot currently be upgraded.  You can remove the problem
>>>> tables and restart the upgrade.
>>>>  So I tried another option but I don't know if this will work. Here's
>>>> my idea:
>>>>  Do a custom dump of the DB in Postgres 8.3.2 + pgis 1.3 .
>>>>  Install 9.2.4 with postgis 2.0.4
>>>> And do a restore with perl script included in the postgis binary
>>>> folder  (perl utils/postgis_restore.pl)
>>>>  do you think it will work?
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>> postgis-users mailing listpostgis-users at lists.osgeo.orghttp://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130708/25ed703d/attachment.html>
