[postgis-users] postgres and postgis upgrade
Racine, Sylvain syracine at sympatico.ca
Tue Jul 9 04:50:46 PDT 2013
On 2013-07-08 16:25, Marcos Cano wrote:
> ubuntu server 12.04... and when i do "echo $PATH" the environment
> variable is blank
Really weird...
Anyway, what you could do first it's to rename the 8.3.2 command to
disable it. Locate "psql" command of your PostgreSQL version 8.3.2, ex.
/usr/bin. Inside the directory, type "sudo mv -i psql psql-8.3.2". Now,
type "psql --version". If the command is found and the version is
changed to 9.2.4, your lucky. If a "command not found" message appears,
you have to add the path of your new version of PostgreSQL commands to
your PATH variable. Here below the process...
To edit PATH variable for your whole Ubuntu system, type "sudo gedit
/etc/environment" (gedit or your favorite editor). A line like
«PATH="....."» should appear. Add your 9.2.4 command path to the
variable. Save the file, close your terminal and reopen it and it should
work. Be carefull in your editing. You could scrap your PATH variable
and lose all your Linux commands. You should make a copy of this file in
your /home directory before editing it. If you scrap it, you could type
the full path of your Linux command, e.g. "sudo /usr/bin/gedit
/etc/environment" to correct the problem or reinstall the backup file.
If the path of your 8.3.2 version is NOT a general path like "/usr/bin"
or "/usr/local/bin", you could remove it from your PATH environment
variable to disable all old PostgreSQL commands. But if it is, you must
rename all the old PostgreSQL command to disable them, ex. pg_dump,
pg_restore, etc.
After those operations, you must type the full path to access old 8.3.2
PostgreSQL commands and type only the command without full path to
access new 9.2.4 PostgreSQL commands.
Hope it will be usefull
Sylvain Racine
> On Mon, Jul 8, 2013 at 9:12 AM, Racine, Sylvain <syracine at sympatico.ca
> <mailto:syracine at sympatico.ca>> wrote:
>     Sorry for the delay. It was the week end. So I closed the
>     computer. To disable psql command for 8.3.2 version, you have to
>     remove the whole path of your old PostgreSQL installation from you
>     PATH variable and replace it by the new one. Depending of the type
>     of OS you use, ex. on Linux, type "echo PATH" to see the paths
>     associated to your system or on Windows, type just "PATH" to see
>     the paths.
>     If you need any help to remove the PostgreSQL 8.3.2 version from
>     PATH variable, please indicate the type of OS you use.
>     Regard
>     Sylvain Racine
>     Le 2013-07-05 11:41, Marcos Cano a écrit :
>>     so when running my script everything went well except that when i
>>     run  "psql --version" it still runs the 8.3.2 version... so to do
>>     psql (9.2.4) i have to indicate the full path to
>>     pgsql9.2.4/bin/psql ..
>>     any idea on how to fix this?
>>     On Thu, Jul 4, 2013 at 4:07 PM, Racine, Sylvain
>>     <syracine at sympatico.ca <mailto:syracine at sympatico.ca>> wrote:
>>         The postgis.sql is a part of the restore process. Because
>>         you'll make hard upgrade of PostGIS, you have to use Perl
>>         script postgis_restore.pl <http://postgis_restore.pl>. This
>>         script removes old PostGIS functions from your backup and
>>         installs the new ones in the new database. Then, you have to
>>         give the path of postgis.sql (or lwpostgis.sql) when you call
>>         postgis_restore.pl <http://postgis_restore.pl> on command line.
>>         I'm not really fan of the new procedure using "CREATE
>>         EXTENSION postgis". It's an automatic process enabled in
>>         PostgreSQL 9.1 and more. With this procedure, you have to use
>>         PostGIS who is embedded with PostgreSQL package. I
>>         encountered earlier some errors when I tried to install
>>         PostGIS using this procedure on a Windows box. But, using the
>>         old procedure I described above, I had the complete control
>>         of the installation and I always got a functionnal database,
>>         even with PostgreSQL 9.2.
>>         Regard
>>         Sylvain Racine
>>         Le 2013-07-04 13:06, Marcos Cano a écrit :
>>>         well i guess while installing and making the postgis i
>>>         installed it against the 9.2.4 (with this : "./configure
>>>         --with-pgconfig=/usr/local/pgsql9.2.4/bin/pg_config" )
>>>         the postgis.sql you mention is to create a spatially enabled
>>>         database? or is it part of the restore process?
>>>         and yes im using the full path to the command to do everything.
>>>         thank you very much i really appreciate it
>>>         On Thu, Jul 4, 2013 at 9:51 AM, Racine, Sylvain
>>>             You have to use pg_dump version 8.3.2 to backup your
>>>             database,e.g. the same version of your source database.
>>>             To restore, use the Perl script and postgis.sql given
>>>             with  Postgis 2.0.4. This script calls pg_dump command.
>>>             It must be pg_dump version 9.2.4, e.g. your destination
>>>             database version. Use "pg_dump --version" to know the
>>>             version of your command.
>>>             You seem use 2 differents versions of PostgreSQL and
>>>             PostGIS on the same computer. To get a particular
>>>             version of a command, type the whole path of the command.
>>>             Regard
>>>             Sylvain Racine
>>>             Le 2013-07-04 10:07, Marcos Cano a écrit :
>>>>             what version of pg_dump should i use?... i tried the
>>>>             8..3.2 and i think it works, but trying the suggested
>>>>             one, wich is the latest (9.2.4) seems just to not work
>>>>             properly because it does not dump my entire database (i
>>>>             assume is because of the mismatch of postgis versions)
>>>>             On Wed, Jul 3, 2013 at 12:00 PM, Paragon Corporation
>>>>             <lr at pcorp.us <mailto:lr at pcorp.us>> wrote:
>>>>                 Yes (custom dump of 8.3.2 + pgis, create new
>>>>                 postgis 2.0.4 in 9.2.4 and restore backup) is the
>>>>                 recommended way.  9.2.4 + 1.5.8 are borderline
>>>>                 compatible so I would avoid that mix and if your
>>>>                 ultimate goal is to go to 2.0, 1.5.8 requires a
>>>>                 hard upgrade anyway so not worth the hassle.
>>>>                 *From:* postgis-users-bounces at lists.osgeo.org
>>>>                 <mailto:postgis-users-bounces at lists.osgeo.org>
>>>>                 [mailto:postgis-users-bounces at lists.osgeo.org
>>>>                 <mailto:postgis-users-bounces at lists.osgeo.org>] *On
>>>>                 Behalf Of *Marcos Cano
>>>>                 *Sent:* Wednesday, July 03, 2013 10:43 AM
>>>>                 *To:* postgis-users at lists.osgeo.org
>>>>                 <mailto:postgis-users at lists.osgeo.org>
>>>>                 *Subject:* [postgis-users] postgres and postgis upgrade
>>>>                 So I'm trying to upgrade Postgres and postgis.. My
>>>>                 current versions are 8.3.2 and 1.3 respectively.
>>>>                 And trying to upgrade to postgis 2.0.4 and Postgres
>>>>                 9.2.4
>>>>                 I've been trying a lot of options like:hard upgrade
>>>>                 of postgis to 1.5.8 in the Postgres 8.3 ( as I'm
>>>>                 sure that version of postgis is compatible with
>>>>                 Postgres 8.3 and 9.2.4)
>>>>                 Then installing postgres 9.2.4 + postgis 1.5.8 and
>>>>                 do a pg_upgrade and finally do a hard upgrade of
>>>>                 postgis to 2.0.4 in the postgres 9.2.4
>>>>                 installation. It  seems to work until an
>>>>                 error happened during the pg_upgrade
>>>>                 Your installation contains the "name" data type in
>>>>                 user tables.  This data type changed its internal
>>>>                 alignment between your old and new clusters so this
>>>>                 cluster cannot currently be upgraded.  You can
>>>>                 remove the problem tables and restart the upgrade.
>>>>                 So I tried another option but I don't know if this
>>>>                 will work. Here's my idea:
>>>>                 Do a custom dump of the DB in Postgres 8.3.2 + pgis
>>>>                 1.3 .
>>>>                 Install 9.2.4 with postgis 2.0.4
>>>>                 And do a restore with perl script included in the
>>>>                 postgis binary folder (perl
>>>>                 utils/postgis_restore.pl <http://postgis_restore.pl>)
>>>>                 do you think it will work?
>>>>                 _______________________________________________
>>>>                 postgis-users mailing list
>>>>                 http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>>>             postgis-users at lists.osgeo.org  <mailto:postgis-users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130709/5f7edddc/attachment.html>
