[postgis-users] postgres and postgis upgrade
Marcos Cano
mcano at stsa.info
Wed Jul 10 13:56:52 PDT 2013
i think i screw it last time... i did not remember to do the echo $PATH in
the postgres user...my bad ...
when i do it in the postgres user the outcome is:
/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/pgsql/bin/
so it is pointing to the 8.3 version (pgsql) my 9.2.4 is
/usr/local/pgsql9.2.4/bin/
so how can i change the env variable without screwing it really bad?
thanks for all your support
On Tue, Jul 9, 2013 at 5:50 AM, Racine, Sylvain <syracine at sympatico.ca>wrote:
> On 2013-07-08 16:25, Marcos Cano wrote:
> ubuntu server 12.04... and when i do "echo $PATH" the environment variable
> is blank
> Really weird...
> Anyway, what you could do first it's to rename the 8.3.2 command to
> disable it. Locate "psql" command of your PostgreSQL version 8.3.2, ex.
> /usr/bin. Inside the directory, type "sudo mv -i psql psql-8.3.2". Now,
> type "psql --version". If the command is found and the version is changed
> to 9.2.4, your lucky. If a "command not found" message appears, you have to
> add the path of your new version of PostgreSQL commands to your PATH
> variable. Here below the process...
> To edit PATH variable for your whole Ubuntu system, type "sudo gedit
> /etc/environment" (gedit or your favorite editor). A line like
> «PATH="....."» should appear. Add your 9.2.4 command path to the variable.
> Save the file, close your terminal and reopen it and it should work. Be
> carefull in your editing. You could scrap your PATH variable and lose all
> your Linux commands. You should make a copy of this file in your /home
> directory before editing it. If you scrap it, you could type the full path
> of your Linux command, e.g. "sudo /usr/bin/gedit /etc/environment" to
> correct the problem or reinstall the backup file.
> If the path of your 8.3.2 version is NOT a general path like "/usr/bin" or
> "/usr/local/bin", you could remove it from your PATH environment variable
> to disable all old PostgreSQL commands. But if it is, you must rename all
> the old PostgreSQL command to disable them, ex. pg_dump, pg_restore, etc.
> After those operations, you must type the full path to access old 8.3.2
> PostgreSQL commands and type only the command without full path to access
> new 9.2.4 PostgreSQL commands.
> Hope it will be usefull
> Sylvain Racine
> On Mon, Jul 8, 2013 at 9:12 AM, Racine, Sylvain <syracine at sympatico.ca>wrote:
>> Sorry for the delay. It was the week end. So I closed the computer. To
>> disable psql command for 8.3.2 version, you have to remove the whole path
>> of your old PostgreSQL installation from you PATH variable and replace it
>> by the new one. Depending of the type of OS you use, ex. on Linux, type
>> "echo PATH" to see the paths associated to your system or on Windows, type
>> just "PATH" to see the paths.
>> If you need any help to remove the PostgreSQL 8.3.2 version from PATH
>> variable, please indicate the type of OS you use.
>> Regard
>> Sylvain Racine
>> Le 2013-07-05 11:41, Marcos Cano a écrit :
>> so when running my script everything went well except that when i run
>> "psql --version" it still runs the 8.3.2 version... so to do psql (9.2.4) i
>> have to indicate the full path to pgsql9.2.4/bin/psql ..
>> any idea on how to fix this?
>> On Thu, Jul 4, 2013 at 4:07 PM, Racine, Sylvain <syracine at sympatico.ca>wrote:
>>> The postgis.sql is a part of the restore process. Because you'll make
>>> hard upgrade of PostGIS, you have to use Perl script postgis_restore.pl.
>>> This script removes old PostGIS functions from your backup and installs the
>>> new ones in the new database. Then, you have to give the path of
>>> postgis.sql (or lwpostgis.sql) when you call postgis_restore.pl on
>>> command line.
>>> I'm not really fan of the new procedure using "CREATE EXTENSION
>>> postgis". It's an automatic process enabled in PostgreSQL 9.1 and more.
>>> With this procedure, you have to use PostGIS who is embedded with
>>> PostgreSQL package. I encountered earlier some errors when I tried to
>>> install PostGIS using this procedure on a Windows box. But, using the old
>>> procedure I described above, I had the complete control of the installation
>>> and I always got a functionnal database, even with PostgreSQL 9.2.
>>> Regard
>>> Sylvain Racine
>>> Le 2013-07-04 13:06, Marcos Cano a écrit :
>>> well i guess while installing and making the postgis i installed it
>>> against the 9.2.4 (with this : "./configure
>>> --with-pgconfig=/usr/local/pgsql9.2.4/bin/pg_config" )
>>> the postgis.sql you mention is to create a spatially enabled database?
>>> or is it part of the restore process?
>>> and yes im using the full path to the command to do everything.
>>> thank you very much i really appreciate it
>>> On Thu, Jul 4, 2013 at 9:51 AM, Racine, Sylvain <syracine at sympatico.ca>wrote:
>>>> You have to use pg_dump version 8.3.2 to backup your database,e.g. the
>>>> same version of your source database. To restore, use the Perl script and
>>>> postgis.sql given with Postgis 2.0.4. This script calls pg_dump command.
>>>> It must be pg_dump version 9.2.4, e.g. your destination database version.
>>>> Use "pg_dump --version" to know the version of your command.
>>>> You seem use 2 differents versions of PostgreSQL and PostGIS on the
>>>> same computer. To get a particular version of a command, type the whole
>>>> path of the command.
>>>> Regard
>>>> Sylvain Racine
>>>> Le 2013-07-04 10:07, Marcos Cano a écrit :
>>>> what version of pg_dump should i use?... i tried the 8..3.2 and i think
>>>> it works, but trying the suggested one, wich is the latest (9.2.4) seems
>>>> just to not work properly because it does not dump my entire database (i
>>>> assume is because of the mismatch of postgis versions)
>>>> On Wed, Jul 3, 2013 at 12:00 PM, Paragon Corporation <lr at pcorp.us>wrote:
>>>>> Yes (custom dump of 8.3.2 + pgis, create new postgis 2.0.4 in 9.2.4
>>>>> and restore backup) is the recommended way. 9.2.4 + 1.5.8 are borderline
>>>>> compatible so I would avoid that mix and if your ultimate goal is to go to
>>>>> 2.0, 1.5.8 requires a hard upgrade anyway so not worth the hassle.
>>>>> *From:* postgis-users-bounces at lists.osgeo.org [mailto:
>>>>> postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Marcos Cano
>>>>> *Sent:* Wednesday, July 03, 2013 10:43 AM
>>>>> *To:* postgis-users at lists.osgeo.org
>>>>> *Subject:* [postgis-users] postgres and postgis upgrade
>>>>> So I'm trying to upgrade Postgres and postgis.. My current versions
>>>>> are 8.3.2 and 1.3 respectively. And trying to upgrade to postgis 2.0.4 and
>>>>> Postgres 9.2.4
>>>>> I've been trying a lot of options like:hard upgrade of postgis to
>>>>> 1.5.8 in the Postgres 8.3 ( as I'm sure that version of postgis is
>>>>> compatible with Postgres 8.3 and 9.2.4)
>>>>> Then installing postgres 9.2.4 + postgis 1.5.8 and do a pg_upgrade and
>>>>> finally do a hard upgrade of postgis to 2.0.4 in the postgres 9.2.4
>>>>> installation. It seems to work until an error happened during the
>>>>> pg_upgrade
>>>>> Your installation contains the "name" data type in user tables. This
>>>>> data type changed its internal alignment between your old and new clusters
>>>>> so this cluster cannot currently be upgraded. You can remove the problem
>>>>> tables and restart the upgrade.
>>>>> So I tried another option but I don't know if this will work. Here's
>>>>> my idea:
>>>>> Do a custom dump of the DB in Postgres 8.3.2 + pgis 1.3 .
>>>>> Install 9.2.4 with postgis 2.0.4
>>>>> And do a restore with perl script included in the postgis binary
>>>>> folder (perl utils/postgis_restore.pl)
>>>>> do you think it will work?
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>>> postgis-users mailing listpostgis-users at lists.osgeo.orghttp://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130710/5c8f406f/attachment.html>
