[postgis-users] postgres and postgis upgrade
Marcos Cano
mcano at stsa.info
Fri Jul 12 10:51:59 PDT 2013
do you think putting the database in a read-only mode before the pg_dump
-Fc should be a good idea??
thank you
On Wed, Jul 10, 2013 at 2:56 PM, Marcos Cano <mcano at stsa.info> wrote:
> i think i screw it last time... i did not remember to do the echo $PATH in
> the postgres user...my bad ...
> when i do it in the postgres user the outcome is:
> /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/pgsql/bin/
> so it is pointing to the 8.3 version (pgsql) my 9.2.4 is
> /usr/local/pgsql9.2.4/bin/
> so how can i change the env variable without screwing it really bad?
> thanks for all your support
> On Tue, Jul 9, 2013 at 5:50 AM, Racine, Sylvain <syracine at sympatico.ca>wrote:
>> On 2013-07-08 16:25, Marcos Cano wrote:
>> ubuntu server 12.04... and when i do "echo $PATH" the environment
>> variable is blank
>> Really weird...
>> Anyway, what you could do first it's to rename the 8.3.2 command to
>> disable it. Locate "psql" command of your PostgreSQL version 8.3.2, ex.
>> /usr/bin. Inside the directory, type "sudo mv -i psql psql-8.3.2". Now,
>> type "psql --version". If the command is found and the version is changed
>> to 9.2.4, your lucky. If a "command not found" message appears, you have to
>> add the path of your new version of PostgreSQL commands to your PATH
>> variable. Here below the process...
>> To edit PATH variable for your whole Ubuntu system, type "sudo gedit
>> /etc/environment" (gedit or your favorite editor). A line like
>> «PATH="....."» should appear. Add your 9.2.4 command path to the variable.
>> Save the file, close your terminal and reopen it and it should work. Be
>> carefull in your editing. You could scrap your PATH variable and lose all
>> your Linux commands. You should make a copy of this file in your /home
>> directory before editing it. If you scrap it, you could type the full path
>> of your Linux command, e.g. "sudo /usr/bin/gedit /etc/environment" to
>> correct the problem or reinstall the backup file.
>> If the path of your 8.3.2 version is NOT a general path like "/usr/bin"
>> or "/usr/local/bin", you could remove it from your PATH environment
>> variable to disable all old PostgreSQL commands. But if it is, you must
>> rename all the old PostgreSQL command to disable them, ex. pg_dump,
>> pg_restore, etc.
>> After those operations, you must type the full path to access old 8.3.2
>> PostgreSQL commands and type only the command without full path to access
>> new 9.2.4 PostgreSQL commands.
>> Hope it will be usefull
>> Sylvain Racine
>> On Mon, Jul 8, 2013 at 9:12 AM, Racine, Sylvain <syracine at sympatico.ca>wrote:
>>> Sorry for the delay. It was the week end. So I closed the computer. To
>>> disable psql command for 8.3.2 version, you have to remove the whole path
>>> of your old PostgreSQL installation from you PATH variable and replace it
>>> by the new one. Depending of the type of OS you use, ex. on Linux, type
>>> "echo PATH" to see the paths associated to your system or on Windows, type
>>> just "PATH" to see the paths.
>>> If you need any help to remove the PostgreSQL 8.3.2 version from PATH
>>> variable, please indicate the type of OS you use.
>>> Regard
>>> Sylvain Racine
>>> Le 2013-07-05 11:41, Marcos Cano a écrit :
>>> so when running my script everything went well except that when i run
>>> "psql --version" it still runs the 8.3.2 version... so to do psql (9.2.4) i
>>> have to indicate the full path to pgsql9.2.4/bin/psql ..
>>> any idea on how to fix this?
>>> On Thu, Jul 4, 2013 at 4:07 PM, Racine, Sylvain <syracine at sympatico.ca>wrote:
>>>> The postgis.sql is a part of the restore process. Because you'll make
>>>> hard upgrade of PostGIS, you have to use Perl script postgis_restore.pl.
>>>> This script removes old PostGIS functions from your backup and installs the
>>>> new ones in the new database. Then, you have to give the path of
>>>> postgis.sql (or lwpostgis.sql) when you call postgis_restore.pl on
>>>> command line.
>>>> I'm not really fan of the new procedure using "CREATE EXTENSION
>>>> postgis". It's an automatic process enabled in PostgreSQL 9.1 and more.
>>>> With this procedure, you have to use PostGIS who is embedded with
>>>> PostgreSQL package. I encountered earlier some errors when I tried to
>>>> install PostGIS using this procedure on a Windows box. But, using the old
>>>> procedure I described above, I had the complete control of the installation
>>>> and I always got a functionnal database, even with PostgreSQL 9.2.
>>>> Regard
>>>> Sylvain Racine
>>>> Le 2013-07-04 13:06, Marcos Cano a écrit :
>>>> well i guess while installing and making the postgis i installed it
>>>> against the 9.2.4 (with this : "./configure
>>>> --with-pgconfig=/usr/local/pgsql9.2.4/bin/pg_config" )
>>>> the postgis.sql you mention is to create a spatially enabled database?
>>>> or is it part of the restore process?
>>>> and yes im using the full path to the command to do everything.
>>>> thank you very much i really appreciate it
>>>> On Thu, Jul 4, 2013 at 9:51 AM, Racine, Sylvain <syracine at sympatico.ca>wrote:
>>>>> You have to use pg_dump version 8.3.2 to backup your database,e.g.
>>>>> the same version of your source database. To restore, use the Perl script
>>>>> and postgis.sql given with Postgis 2.0.4. This script calls pg_dump
>>>>> command. It must be pg_dump version 9.2.4, e.g. your destination database
>>>>> version. Use "pg_dump --version" to know the version of your command.
>>>>> You seem use 2 differents versions of PostgreSQL and PostGIS on the
>>>>> same computer. To get a particular version of a command, type the whole
>>>>> path of the command.
>>>>> Regard
>>>>> Sylvain Racine
>>>>> Le 2013-07-04 10:07, Marcos Cano a écrit :
>>>>> what version of pg_dump should i use?... i tried the 8..3.2 and i
>>>>> think it works, but trying the suggested one, wich is the latest (9.2.4)
>>>>> seems just to not work properly because it does not dump my entire database
>>>>> (i assume is because of the mismatch of postgis versions)
>>>>> On Wed, Jul 3, 2013 at 12:00 PM, Paragon Corporation <lr at pcorp.us>wrote:
>>>>>> Yes (custom dump of 8.3.2 + pgis, create new postgis 2.0.4 in 9.2.4
>>>>>> and restore backup) is the recommended way. 9.2.4 + 1.5.8 are borderline
>>>>>> compatible so I would avoid that mix and if your ultimate goal is to go to
>>>>>> 2.0, 1.5.8 requires a hard upgrade anyway so not worth the hassle.
>>>>>> *From:* postgis-users-bounces at lists.osgeo.org [mailto:
>>>>>> postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Marcos Cano
>>>>>> *Sent:* Wednesday, July 03, 2013 10:43 AM
>>>>>> *To:* postgis-users at lists.osgeo.org
>>>>>> *Subject:* [postgis-users] postgres and postgis upgrade
>>>>>> So I'm trying to upgrade Postgres and postgis.. My current
>>>>>> versions are 8.3.2 and 1.3 respectively. And trying to upgrade to
>>>>>> postgis 2.0.4 and Postgres 9.2.4
>>>>>> I've been trying a lot of options like:hard upgrade of postgis to
>>>>>> 1.5.8 in the Postgres 8.3 ( as I'm sure that version of postgis is
>>>>>> compatible with Postgres 8.3 and 9.2.4)
>>>>>> Then installing postgres 9.2.4 + postgis 1.5.8 and do a pg_upgrade
>>>>>> and finally do a hard upgrade of postgis to 2.0.4 in the postgres 9.2.4
>>>>>> installation. It seems to work until an error happened during the
>>>>>> pg_upgrade
>>>>>> Your installation contains the "name" data type in user tables. This
>>>>>> data type changed its internal alignment between your old and new clusters
>>>>>> so this cluster cannot currently be upgraded. You can remove the problem
>>>>>> tables and restart the upgrade.
>>>>>> So I tried another option but I don't know if this will work.
>>>>>> Here's my idea:
>>>>>> Do a custom dump of the DB in Postgres 8.3.2 + pgis 1.3 .
>>>>>> Install 9.2.4 with postgis 2.0.4
>>>>>> And do a restore with perl script included in the postgis binary
>>>>>> folder (perl utils/postgis_restore.pl)
>>>>>> do you think it will work?
>>>>>> _______________________________________________
>>>>>> postgis-users mailing list
>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>>>> postgis-users mailing listpostgis-users at lists.osgeo.orghttp://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130712/22a0cc0a/attachment.html>
