[postgis-users] Qgis/Postgis : impossible to open a project
Morten Sickel morten at sickel.net
Tue Jul 9 07:40:45 PDT 2013
You need to change the connection info from localhost (i.e. "the computer
I am working on now") to a name or ip-address that can be reached from the
other computers you want to work on your project from. Given that the
postgres server is set up to allow access to other computers (correctly
set listen_address in postgresql.conf) this will also work fine from the
host you originally was working on.
Alternatively - if it is a static data base, you can install copies of it
on all computers you want to work on.
the qgis project file is an xml-file, so you can open (or preferably a
copy of it...) in a text editor and change the connection information
directly - just search through it to make sure you change it everywhere
through the file...  (the connection information looks pretty much like
the text in the dialog box you sent)
Hope this helps.
Morten
Bborie Park skrev:
> That error message indicates that the the PostgreSQL connection string
> points to localhost, which would be the local computer. On your station,
> localhost has a PostgreSQL server. On those other stations having that
> error, they don't have a PostgreSQL server.
> -bborie
> On Tue, Jul 9, 2013 at 6:43 AM, laurent
> <lcelati at latitude-geosystems.com>wrote:
>> Hello,
>> My windows 7 station hosts a postresql/postgis server (9.1). On this
>> station
>> i succeed in saving a qgis (1.8) project with several postgis layers
>> (vector).
>> I saved this qgis project on our network. So i thought to be able to
>> open
>> this project from any station. But when i try to do that, i receive a
>> message error when i try to open the project from other stations. Please
>> to
>> find below attached representing the error message.
>> <http://postgis.17.x6.nabble.com/file/n5003712/SS_postgis_credits.jpg>
>> Could you throw light for me please? Thanks.
>> View this message in context:
>> http://postgis.17.x6.nabble.com/Qgis-Postgis-impossible-to-open-a-project-tp5003712.html
>> Sent from the PostGIS - User mailing list archive at Nabble.com.
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
