[postgis-users] Debugging shp2pgsql inserts
Travis Kirstine
traviskirstine at gmail.com
Fri Jul 19 10:43:15 PDT 2013
I've been attempting to import a large shapefile into postgis and I keep
running into "ERROR: current transaction is aborted, commands ignored
until end of transaction block" when importing the data.
Is there a easy method to determine which INSERT causes the transaction to
fail? It appears the only why is to catch the stdout as soon as psql errors
shp2pgsql -I -W LATIN1 -s 3857 mybigshp.shp mytbl > mysql.sql
psql -U user -o log.txt mydb < mysql.sql
Thanks
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130719/ac6508eb/attachment.html>
