[postgis-users] Debugging shp2pgsql inserts
Wilkins, Brian bwilkins at harris.com
Fri Jul 19 10:48:20 PDT 2013
It should be the last one at the top where all those ERROR messages get displayed. The first to fail stops everything.
From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Travis Kirstine
Sent: Friday, July 19, 2013 1:43 PM
To: PostGIS Users Discussion
Subject: [postgis-users] Debugging shp2pgsql inserts
I've been attempting to import a large shapefile into postgis and I keep running into "ERROR:  current transaction is aborted, commands ignored until end of transaction block" when importing the data.
 Is there a easy method to determine which INSERT causes the transaction to fail? It appears the only why is to catch the stdout as soon as psql errors
shp2pgsql -I -W LATIN1 -s 3857 mybigshp.shp mytbl > mysql.sql
psql -U user -o log.txt mydb < mysql.sql
Thanks
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130719/be0d80d7/attachment.html>
