[postgis-users] Left of/Right of test
Denis Rouzaud
denis.rouzaud at gmail.com
Tue Jul 23 07:48:08 PDT 2013
Oops, here is the complete code:
pointGeom << ST_Intersection( ST_MakeLine(
ST_MakePoint(ST_XMin(lineGeom), ST_Y(pointGeom)),
ST_MakePoint(ST_XMax(lineGeom), ST_Y(pointGeom))
), lineGeom
On 07/23/2013 04:31 PM, Denis Rouzaud wrote:
> Hi Andreas,
> Do you mean you want to test to a segment?
> Because, I can't see a true answer for a line.
> If you want to do test to a segment, it should do the job to test if
> the intersection with the horizontal line (dy=0) over your point and
> your input line is on the left/right to your point.
> So, maybe test:
> You have to handle the case where your segment is horizontal, but then
> a simple test with ST_Xmin/max should be enough.
> Cheers,
> Denis
> On 07/23/2013 03:54 PM, Andreas Neumann wrote:
>> Hi,
>> I want to test a point if it is left-of or right-of a given LINESTRING.
>> I found the << >> and &< &> but they do not behave like I expected.
>> Perhaps it is because they only test on the bounding box level and not
>> on the real geometry?
>> Is there a left/right of test available on the geometry instead of the
>> bounding box?
>> Thank you,
>> Andreas
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
