[postgis-users] Left of/Right of test
Andreas Neumann a.neumann at carto.net
Tue Jul 23 08:03:28 PDT 2013
Hi Denis,
Thank you for your reply.
Actually I really want to test a LINESTRING against POLYGON centroids
(determined with ST_PointOnSurface), not just a line against a point.
Is this question not answerable? As a human I can determine it. I am
aware about the edge cases where a point is on the line, but in my case
this can't happen as the data comes from a correctly defined polygon mosaic.
>From the lines of a polygon mosaic (directed lines node to node, no
double lines) I want to label what is left and what is right of a
polygon border. My theme is usage zones and I should label what is left
and right of the polygon border.
Andreas
Am 23.07.2013 16:48, schrieb Denis Rouzaud:
> Oops, here is the complete code:
> pointGeom << ST_Intersection( ST_MakeLine(
>              ST_MakePoint(ST_XMin(lineGeom), ST_Y(pointGeom)),
>              ST_MakePoint(ST_XMax(lineGeom), ST_Y(pointGeom))
>                           ), lineGeom
> On 07/23/2013 04:31 PM, Denis Rouzaud wrote:
>> Hi Andreas,
>> Do you mean you want to test to a segment?
>> Because, I can't see a true answer for a line.
>> If you want to do test to a segment, it should do the job to test if
>> the intersection with the horizontal line (dy=0) over your point and
>> your input line is on the left/right to your point.
>> So, maybe test:
>> You have to handle the case where your segment is horizontal, but then
>> a simple test with ST_Xmin/max should be enough.
>> Cheers,
>> Denis
>> On 07/23/2013 03:54 PM, Andreas Neumann wrote:
>>> Hi,
>>> I want to test a point if it is left-of or right-of a given LINESTRING.
>>> I found the << >> and &< &> but they do not behave like I expected.
>>> Perhaps it is because they only test on the bounding box level and not
>>> on the real geometry?
>>> Is there a left/right of test available on the geometry instead of the
>>> bounding box?
>>> Thank you,
>>> Andreas
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
