[postgis-users] Left of/Right of test
Randall, Eric
ERandall at eriecountygov.org
Tue Jul 23 08:34:43 PDT 2013
If line goes from A to B and point is P,
v = (Ay-By)*Px+(Bx-Ax)*Py+(Ax*By-Bx*Ay)
v>0: "Left"
v<0: "Right"
v=0: "On the line"
(or in front of B / behind A)
Example:
select sites_gid, roads_gid, case when
( st_y(st_startpoint(sline)) - st_y(st_endpoint(sline)) ) * st_x(cpoint)
+ ( st_x(st_endpoint(sline)) - st_x(st_startpoint(sline)) ) * st_y(cpoint)
+ ( st_x(st_startpoint(sline)) * st_y(st_endpoint(sline)) - st_x(st_endpoint(sline))
* st_y(st_startpoint(sline)) ) > 0
then 'L'
when
* st_y(st_startpoint(sline)) ) < 0
then 'R'
when
* st_y(st_startpoint(sline)) ) = 0
then null
end
as side
from ...
Eric Randall, GIS DB Admin/Analyst
County of Erie, Pa
140 West 6th Street
Room 111
Erie, Pa 16501
Ph. 814-451-6063
Fx. 814-451-7000
L'unica via d'uscita è dentro
--Alice
-----Original Message-----
From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Andreas Neumann
Sent: Tuesday, July 23, 2013 11:03 AM
To: Denis Rouzaud
Cc: PostGIS Users Discussion
Subject: Re: [postgis-users] Left of/Right of test
Hi Denis,
Thank you for your reply.
Actually I really want to test a LINESTRING against POLYGON centroids (determined with ST_PointOnSurface), not just a line against a point.
Is this question not answerable? As a human I can determine it. I am aware about the edge cases where a point is on the line, but in my case this can't happen as the data comes from a correctly defined polygon mosaic.
>From the lines of a polygon mosaic (directed lines node to node, no double lines) I want to label what is left and what is right of a polygon border. My theme is usage zones and I should label what is left and right of the polygon border.
Andreas
Am 23.07.2013 16:48, schrieb Denis Rouzaud:
> Oops, here is the complete code:
> pointGeom << ST_Intersection( ST_MakeLine(
> ST_MakePoint(ST_XMin(lineGeom), ST_Y(pointGeom)),
> ST_MakePoint(ST_XMax(lineGeom), ST_Y(pointGeom))
> ), lineGeom
> On 07/23/2013 04:31 PM, Denis Rouzaud wrote:
>> Hi Andreas,
>> Do you mean you want to test to a segment?
>> Because, I can't see a true answer for a line.
>> If you want to do test to a segment, it should do the job to test if
>> the intersection with the horizontal line (dy=0) over your point and
>> your input line is on the left/right to your point.
>> So, maybe test:
>> You have to handle the case where your segment is horizontal, but
>> then a simple test with ST_Xmin/max should be enough.
>> Cheers,
>> Denis
>> On 07/23/2013 03:54 PM, Andreas Neumann wrote:
>>> Hi,
>>> I want to test a point if it is left-of or right-of a given LINESTRING.
>>> I found the << >> and &< &> but they do not behave like I expected.
>>> Perhaps it is because they only test on the bounding box level and
>>> not on the real geometry?
>>> Is there a left/right of test available on the geometry instead of
>>> the bounding box?
>>> Thank you,
>>> Andreas
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
