[postgis-users] Left of/Right of test
Randall, Eric
ERandall at eriecountygov.org
Tue Jul 23 08:22:12 PDT 2013
I use this. Works but its quite a few years old, maybe another way now.
If line goes from A to B and point is P,
v = (Ay-By)*Px+(Bx-Ax)*Py+(Ax*By-Bx*Ay)
v>0: "Left"
v<0: "Right"
v=0: "On the line"
(or in front of B / behind A)
select sites_gid, roads_gid, case when
( st_y(st_startpoint(sline)) - st_y(st_endpoint(sline)) ) * st_x(cpoint)
+ ( st_x(st_endpoint(sline)) - st_x(st_startpoint(sline)) ) * st_y(cpoint)
+ ( st_x(st_startpoint(sline)) * st_y(st_endpoint(sline)) - st_x(st_endpoint(sline))
* st_y(st_startpoint(sline)) ) > 0
then 'L'
when
* st_y(st_startpoint(sline)) ) < 0
then 'R'
when
* st_y(st_startpoint(sline)) ) = 0
then null
end
as side
from ...
Eric Randall, GIS DB Admin/Analyst
County of Erie, Pa
140 West 6th Street
Room 111
Erie, Pa 16501
Ph. 814-451-6063
Fx. 814-451-7000
L'unica via d'uscita è dentro
--Alice
-----Original Message-----
From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Andreas Neumann
Sent: Tuesday, July 23, 2013 9:54 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Left of/Right of test
I want to test a point if it is left-of or right-of a given LINESTRING.
I found the << >> and &< &> but they do not behave like I expected.
Perhaps it is because they only test on the bounding box level and not on the real geometry?
Is there a left/right of test available on the geometry instead of the bounding box?
Thank you,
Andreas
postgis-users mailing list
postgis-users at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
