[postgis-users] Querying Multiple Rasters
Jayson Gallardo jaysontrades at gmail.com
Tue Jul 30 09:42:56 PDT 2013
I was reading the page on partitioning, and the very last line says*
"**Partitioning
using these techniques will work well with up to perhaps a hundred
partitions; don't try to use many thousands of partitions." *I'm already up
to ~400 tables in this partitioning scheme just for Arkansas and Iowa... Is
this a good idea? Would there be a better way to do the entire continental
US?
On Tue, Jul 30, 2013 at 11:39 AM, Bborie Park <dustymugs at gmail.com> wrote:
> The quick and dirty approach is to have a query before that query that
> transforms the WKT.
> Something like "SELECT ST_AsEWKT(ST_Transform(...))"
> -bborie
> On Tue, Jul 30, 2013 at 9:35 AM, Jayson Gallardo <jaysontrades at gmail.com>wrote:
>> I suppose I could do that in my script. How should I go about that? My
>> process is as follows:
>>    - User selects area of interest on a map (openlayers)
>>    - User clicks submit, and python script is called with the WKT passed
>>    as an argument
>>    - Python script queries the database, which then outputs the raster
>>    - Raster is processed through a library
>>    - Processed raster is displayed as an overlay on the map
>> On Tue, Jul 30, 2013 at 11:31 AM, Bborie Park <dustymugs at gmail.com>wrote:
>>> Are you able to transform the wkt before passing it to the sql?
>>> Partitioning only works on constant values, not values that need
>>> processing, e.g. ST_Transform(ST_GeomFromText(\'%s\',%i),%i)).
>>> -bborie
>>> On Tue, Jul 30, 2013 at 9:25 AM, Jayson Gallardo <jaysontrades at gmail.com
>>> > wrote:
>>>> Here's the constraints:
>>>>   CONSTRAINT dem_elevation_n33w092_pkey PRIMARY KEY (rid ),
>>>>   CONSTRAINT enforce_height_rast CHECK (st_height(rast) = 100),
>>>>   CONSTRAINT enforce_max_extent_rast CHECK
>>>> (st_coveredby(st_convexhull(rast), '*...truncated...*'::geometry)),
>>>>   CONSTRAINT enforce_num_bands_rast CHECK (st_numbands(rast) = 1),
>>>>   CONSTRAINT enforce_out_db_rast CHECK (_raster_constraint_out_db(rast)
>>>> = '{f}'::boolean[]),
>>>>   CONSTRAINT enforce_pixel_types_rast CHECK
>>>> (_raster_constraint_pixel_types(rast) = '{32BF}'::text[]),
>>>>   CONSTRAINT enforce_same_alignment_rast CHECK (st_samealignment(rast, '
>>>> *...truncated...*'::raster)),
>>>>   CONSTRAINT enforce_scalex_rast CHECK (st_scalex(rast)::numeric(16,10)
>>>> = 0.000092592592593::numeric(16,10)),
>>>>   CONSTRAINT enforce_scaley_rast CHECK (st_scaley(rast)::numeric(16,10)
>>>> = (-0.000092592592593)::numeric(16,10)),
>>>>   CONSTRAINT enforce_srid_rast CHECK (st_srid(rast) = 4269),
>>>>   CONSTRAINT enforce_width_rast CHECK (st_width(rast) = 100)
>>>> and my python script:
>>>> wkt = sys.argv[1]  # Polygon shape in WKT format
>>>> raster_type = 'GTiff'
>>>> table_name = 'dem_elevation'
>>>> map_srs = 900913
>>>> table_srs = 4269
>>>> sql_text = 'SELECT ST_AsGDALRaster(ST_CLIP(ST_Union(rast),
>>>> ST_GeomFromText(\'%s\',%i)),\'%s\') FROM "%s" WHERE
>>>> ST_Intersects(rast, ST_Transform(ST_GeomFromText(\'%s\',%i),%i))' %
>>>> (wkt, map_srs, raster_type, table_name, wkt, map_srs, table_srs)
>>>> On Tue, Jul 30, 2013 at 11:12 AM, Bborie Park <dustymugs at gmail.com>wrote:
>>>>> Jayson,
>>>>> Can you share one of the queries? Also, what check constraints are you
>>>>> using?
>>>>> -bborie
>>>>> On Tue, Jul 30, 2013 at 7:49 AM, Jayson Gallardo <
>>>>> jaysontrades at gmail.com> wrote:
>>>>>> So, I used Explain on my SELECT statement, and whether
>>>>>> constraint_exclusion is on or off, it seems to spit out the same number of
>>>>>> rows in the query plan. Is there something I need to do for my table
>>>>>> constraints so that it doesn't do a check on every table I have loaded?
>>>>>> On Tue, Jul 30, 2013 at 9:20 AM, Jayson Gallardo <
>>>>>>> Quick follow up question to my situation... I recently loaded 3m
>>>>>>> resolution NED for Iowa. I have them loaded to one table per source tile,
>>>>>>> and have them inheriting from the parent table that the Arkansas NED is
>>>>>>> inheriting from. Ever since, however, my database seems to be running
>>>>>>> pretty slow. I've run a full vacuum on the data, and there are constraints
>>>>>>> on each table.
>>>>>>> How can I be sure that when I query the parent database that it's
>>>>>>> not querying every single table?
>>>>>>> On Tue, Jul 23, 2013 at 3:14 PM, Bborie Park <dustymugs at gmail.com>wrote:
>>>>>>>> I'm just glad to help. Feel free to post your experience, feedback,
>>>>>>>> issues and/or wishes on the mailing-list.
>>>>>>>> -bborie
>>>>>>>> On Tue, Jul 23, 2013 at 1:10 PM, Jayson Gallardo <
>>>>>>>>> Oh, okay. Yeah you're right about it taking time. I wrote a python
>>>>>>>>> script to generate the raster2pgsql call with the appropriate table name,
>>>>>>>>> so I can just let it run while I do other things. I really appreciate your
>>>>>>>>> help on this. I googled your name and I see you're a pretty busy person, so
>>>>>>>>> I'm glad you're taking the time to answer my questions.
>>>>>>>>> On Tue, Jul 23, 2013 at 3:05 PM, Bborie Park <dustymugs at gmail.com>wrote:
>>>>>>>>>> No. I'm suggesting it later as it does take time and separates
>>>>>>>>>> operations. Get everything imported first and then add constraints.
>>>>>>>>>> Having said that, you can do it all at once if so desired... just
>>>>>>>>>> preference depending on volume of import data.
>>>>>>>>>> -bborie
>>>>>>>>>> On Tue, Jul 23, 2013 at 1:02 PM, Jayson Gallardo <
>>>>>>>>>>> Okay, is there a specific reason why? As your link states: "
>>>>>>>>>>> raster2pgsql loader uses this function to register raster
>>>>>>>>>>> tables". Are you saying I should specify constraints that will be similar
>>>>>>>>>>> across all tables?
>>>>>>>>>>> On Tue, Jul 23, 2013 at 2:53 PM, Bborie Park <
>>>>>>>>>>>> I'd suggest adding constraints after the fact through SQL
>>>>>>>>>>>> instead of letting raster2pgsql do it.
>>>>>>>>>>>> http://www.postgis.net/docs/manual-2.0/RT_AddRasterConstraints.html
>>>>>>>>>>>> -bborie
>>>>>>>>>>>> On Tue, Jul 23, 2013 at 12:51 PM, Jayson Gallardo <
>>>>>>>>>>>>> So based on the link you provided, and what else I've
>>>>>>>>>>>>> gathered, I first create a parent table:
>>>>>>>>>>>>>  CREATE TABLE dem_elevation
>>>>>>>>>>>>>   rid integer NOT NULL PRIMARY KEY
>>>>>>>>>>>>>   rast raster,
>>>>>>>>>>>>>  Then I run raster2pgsql on all the downloaded elevation data,
>>>>>>>>>>>>> sending each input tile to its own table, ie. dem_elevation_n36w091. Then
>>>>>>>>>>>>> alter table to inherit from parent:
>>>>>>>>>>>>> ALTER TABLE dem_elevation_n36w091 INHERIT dem_elevation;
>>>>>>>>>>>>> With raster2pgsql taking care of setting the constraints for
>>>>>>>>>>>>> each table. Now, I can just query the parent table dem_elevation to get
>>>>>>>>>>>>> what I need?
>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 2:33 PM, Bborie Park <
>>>>>>>>>>>>>> I use the USGS NED 10 meter for California with one table for
>>>>>>>>>>>>>> each input raster. In the partitioned table scheme, data tables inherit
>>>>>>>>>>>>>> from a template (parent) table. Queries run on the parent table access the
>>>>>>>>>>>>>> inherited tables.
>>>>>>>>>>>>>> -bborie
>>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 11:56 AM, Jayson Gallardo <
>>>>>>>>>>>>>>> Yes, it's usgs ned. And I initially went with one table for
>>>>>>>>>>>>>>> each input tile, but I didn't know how to join (or union) them together for
>>>>>>>>>>>>>>> my query.
>>>>>>>>>>>>>>>  On Jul 23, 2013 1:14 PM, "Bborie Park" <dustymugs at gmail.com>
>>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>>> Can you describe your elevation dataset? Is it USGS NED? At
>>>>>>>>>>>>>>>> which resolution (10 meter, 3 meter?)?
>>>>>>>>>>>>>>>> As for table partitioning...
>>>>>>>>>>>>>>>> http://www.postgresql.org/docs/9.0/static/ddl-partitioning.html
>>>>>>>>>>>>>>>> You'll probably partition spatially, though an easy
>>>>>>>>>>>>>>>> solution is to have a table for each input raster file.
>>>>>>>>>>>>>>>> -bborie
>>>>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 11:05 AM, Jayson Gallardo <
>>>>>>>>>>>>>>>>> Thanks for responding. Could you outline how I would go
>>>>>>>>>>>>>>>>> about doing a partitioned table structure? My only concern with tile size
>>>>>>>>>>>>>>>>> is processing time. Most of my queries will involve areas of less than 1
>>>>>>>>>>>>>>>>> mi^2, and I would clip the data into that shape. I just don't know where to
>>>>>>>>>>>>>>>>> start! There's not too many resources online/print dealing with postgis
>>>>>>>>>>>>>>>>> rasters in detail.
>>>>>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 12:57 PM, Bborie Park <
>>>>>>>>>>>>>>>>>> You may not need to drop all the constraints when adding
>>>>>>>>>>>>>>>>>> additional data to the table. You most likely will need to drop is the
>>>>>>>>>>>>>>>>>> maximum extent constraint. Assuming the input rasters have the same scale,
>>>>>>>>>>>>>>>>>> skew and SRID as that found in the table, you don't need to drop those
>>>>>>>>>>>>>>>>>> corresponding constraints.
>>>>>>>>>>>>>>>>>> If you're going to do the continental US at a fine
>>>>>>>>>>>>>>>>>> resolution (e.g. 1 meter), you do NOT want to put all the rasters in one
>>>>>>>>>>>>>>>>>> table. You'll want to use a partitioned table structure and should consider
>>>>>>>>>>>>>>>>>> a bigger tile size (depending on your hardware).
>>>>>>>>>>>>>>>>>> -bborie
>>>>>>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 10:43 AM, Jayson Gallardo <
>>>>>>>>>>>>>>>>>>> I've looked and looked, but I have not been able to find
>>>>>>>>>>>>>>>>>>> an answer to my question. I have downloaded elevation data for the state of
>>>>>>>>>>>>>>>>>>> Arkansas (in the form of multiple tiles), and used raster2pgsql to upload
>>>>>>>>>>>>>>>>>>> it into a single table:
>>>>>>>>>>>>>>>>>>> raster2pgsql -I -C -e -F -t 50x50 -l 2,4 n*/grdn*
>>>>>>>>>>>>>>>>>>> public.dem_elevation | psql -U postgres -d testdb -h localhost -p 5432
>>>>>>>>>>>>>>>>>>> I did this because I didn't know how to pull the data if
>>>>>>>>>>>>>>>>>>> they were in separate tables. Now, however I would like to add elevation
>>>>>>>>>>>>>>>>>>> data for other areas. I tried to just add it to the current table, but that
>>>>>>>>>>>>>>>>>>> required dropping the constraints which for such a huge amount of data
>>>>>>>>>>>>>>>>>>> seems to take a long time (I let it run for 24+ hours and it didn't
>>>>>>>>>>>>>>>>>>> finish). So, my question is, if I load all my rasters as individual tables,
>>>>>>>>>>>>>>>>>>> how could I run something similar to this query on them all (from a python
>>>>>>>>>>>>>>>>>>> script):
>>>>>>>>>>>>>>>>>>> ST_GeomFromText(WKT,900913)),'GTiff') FROM "dem_elevation" WHERE
>>>>>>>>>>>>>>>>>>> ST_Intersects(rast, ST_Transform(ST_GeomFromText(WKT,900913),4269))
>>>>>>>>>>>>>>>>>>> My goal, if it's not obvious, is to clip elevation data
>>>>>>>>>>>>>>>>>>> and export it to a GTiff format and perform some operations on that raster
>>>>>>>>>>>>>>>>>>> data. Eventually, I would like to put the whole continental US elevation
>>>>>>>>>>>>>>>>>>> data into my database, so I need to be able to do so, while still being
>>>>>>>>>>>>>>>>>>> able to query them based on an area of interest the user selects from a
>>>>>>>>>>>>>>>>>>> map. I started working with PostGIS and Mapserver last month, so please
>>>>>>>>>>>>>>>>>>> forgive my ignorance on such topics. Thanks in advance
>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>> postgis-users mailing list
>>>>>>>>>>>>>>>>>>> postgis-users at lists.osgeo.org
>>>>>>>>>>>>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130730/55829bb7/attachment.html>
