[postgis-users] Querying Multiple Rasters
Jayson Gallardo jaysontrades at gmail.com
Tue Jul 30 10:06:13 PDT 2013
Thanks for the help again. There will be extensive testing before we go
into production. Right now, we're just trying to get a prototype up and
running. I might need to look into querying a web service for clipped NED
data...
On Tue, Jul 30, 2013 at 12:01 PM, Bborie Park <dustymugs at gmail.com> wrote:
> That should work if you're querying against the subparent instead of the
> parent. You'll need to test though...
> -bborie
> On Tue, Jul 30, 2013 at 9:59 AM, Jayson Gallardo <jaysontrades at gmail.com>wrote:
>> What if I create subparents for each state, and set an extent constraint
>> on each subparent? Would that help? Or would the query still check the
>> constraint for each child of each subparent?
>> On Tue, Jul 30, 2013 at 11:54 AM, Bborie Park <dustymugs at gmail.com>wrote:
>>> 3m NED data doesn't exist for the continental US (at least from USGS).
>>> But if you were to do so, you could consider a different scheme...
>>> 1. All NED files are stored as out-db rasters
>>> 2. Each table is for one state, though in some situations you may want
>>> more than one table per state (e.g. Texas, California).
>>> That should help you keep the # of partitions to a minimum and reduce
>>> the size of each partition.
>>> -bborie
>>> On Tue, Jul 30, 2013 at 9:42 AM, Jayson Gallardo <jaysontrades at gmail.com
>>> > wrote:
>>>> I was reading the page on partitioning, and the very last line says* "*
>>>> *Partitioning using these techniques will work well with up to perhaps
>>>> a hundred partitions; don't try to use many thousands of partitions." *I'm
>>>> already up to ~400 tables in this partitioning scheme just for Arkansas and
>>>> Iowa... Is this a good idea? Would there be a better way to do the entire
>>>> continental US?
>>>> On Tue, Jul 30, 2013 at 11:39 AM, Bborie Park <dustymugs at gmail.com>wrote:
>>>>> The quick and dirty approach is to have a query before that query that
>>>>> transforms the WKT.
>>>>> Something like "SELECT ST_AsEWKT(ST_Transform(...))"
>>>>> -bborie
>>>>> On Tue, Jul 30, 2013 at 9:35 AM, Jayson Gallardo <
>>>>> jaysontrades at gmail.com> wrote:
>>>>>> I suppose I could do that in my script. How should I go about that?
>>>>>> My process is as follows:
>>>>>>    - User selects area of interest on a map (openlayers)
>>>>>>    - User clicks submit, and python script is called with the WKT
>>>>>>    passed as an argument
>>>>>>    - Python script queries the database, which then outputs the
>>>>>>    raster
>>>>>>    - Raster is processed through a library
>>>>>>    - Processed raster is displayed as an overlay on the map
>>>>>> On Tue, Jul 30, 2013 at 11:31 AM, Bborie Park <dustymugs at gmail.com>wrote:
>>>>>>> Are you able to transform the wkt before passing it to the sql?
>>>>>>> Partitioning only works on constant values, not values that need
>>>>>>> processing, e.g. ST_Transform(ST_GeomFromText(\'%s\',%i),%i)).
>>>>>>> -bborie
>>>>>>> On Tue, Jul 30, 2013 at 9:25 AM, Jayson Gallardo <
>>>>>>>> Here's the constraints:
>>>>>>>>   CONSTRAINT dem_elevation_n33w092_pkey PRIMARY KEY (rid ),
>>>>>>>>   CONSTRAINT enforce_height_rast CHECK (st_height(rast) = 100),
>>>>>>>>   CONSTRAINT enforce_max_extent_rast CHECK
>>>>>>>> (st_coveredby(st_convexhull(rast), '*...truncated...*'::geometry)),
>>>>>>>>   CONSTRAINT enforce_num_bands_rast CHECK (st_numbands(rast) = 1),
>>>>>>>>   CONSTRAINT enforce_out_db_rast CHECK
>>>>>>>> (_raster_constraint_out_db(rast) = '{f}'::boolean[]),
>>>>>>>>   CONSTRAINT enforce_pixel_types_rast CHECK
>>>>>>>> (_raster_constraint_pixel_types(rast) = '{32BF}'::text[]),
>>>>>>>>   CONSTRAINT enforce_same_alignment_rast CHECK
>>>>>>>> (st_samealignment(rast, '*...truncated...*'::raster)),
>>>>>>>>   CONSTRAINT enforce_scalex_rast CHECK
>>>>>>>> (st_scalex(rast)::numeric(16,10) = 0.000092592592593::numeric(16,10)),
>>>>>>>>   CONSTRAINT enforce_scaley_rast CHECK
>>>>>>>> (st_scaley(rast)::numeric(16,10) = (-0.000092592592593)::numeric(16,10)),
>>>>>>>>   CONSTRAINT enforce_srid_rast CHECK (st_srid(rast) = 4269),
>>>>>>>>   CONSTRAINT enforce_width_rast CHECK (st_width(rast) = 100)
>>>>>>>> and my python script:
>>>>>>>> wkt = sys.argv[1]  # Polygon shape in WKT format
>>>>>>>> raster_type = 'GTiff'
>>>>>>>> table_name = 'dem_elevation'
>>>>>>>> map_srs = 900913
>>>>>>>> table_srs = 4269
>>>>>>>> sql_text = 'SELECT ST_AsGDALRaster(ST_CLIP(ST_Union(rast),
>>>>>>>> ST_GeomFromText(\'%s\',%i)),\'%s\') FROM "%s" WHERE
>>>>>>>> ST_Intersects(rast, ST_Transform(ST_GeomFromText(\'%s\',%i),%i))' %
>>>>>>>> (wkt, map_srs, raster_type, table_name, wkt, map_srs, table_srs)
>>>>>>>> On Tue, Jul 30, 2013 at 11:12 AM, Bborie Park <dustymugs at gmail.com>wrote:
>>>>>>>>> Jayson,
>>>>>>>>> Can you share one of the queries? Also, what check constraints are
>>>>>>>>> you using?
>>>>>>>>> -bborie
>>>>>>>>> On Tue, Jul 30, 2013 at 7:49 AM, Jayson Gallardo <
>>>>>>>>>> So, I used Explain on my SELECT statement, and whether
>>>>>>>>>> constraint_exclusion is on or off, it seems to spit out the same number of
>>>>>>>>>> rows in the query plan. Is there something I need to do for my table
>>>>>>>>>> constraints so that it doesn't do a check on every table I have loaded?
>>>>>>>>>> On Tue, Jul 30, 2013 at 9:20 AM, Jayson Gallardo <
>>>>>>>>>>> Quick follow up question to my situation... I recently loaded 3m
>>>>>>>>>>> resolution NED for Iowa. I have them loaded to one table per source tile,
>>>>>>>>>>> and have them inheriting from the parent table that the Arkansas NED is
>>>>>>>>>>> inheriting from. Ever since, however, my database seems to be running
>>>>>>>>>>> pretty slow. I've run a full vacuum on the data, and there are constraints
>>>>>>>>>>> on each table.
>>>>>>>>>>> How can I be sure that when I query the parent database that
>>>>>>>>>>> it's not querying every single table?
>>>>>>>>>>> On Tue, Jul 23, 2013 at 3:14 PM, Bborie Park <
>>>>>>>>>>>> I'm just glad to help. Feel free to post your experience,
>>>>>>>>>>>> feedback, issues and/or wishes on the mailing-list.
>>>>>>>>>>>> -bborie
>>>>>>>>>>>> On Tue, Jul 23, 2013 at 1:10 PM, Jayson Gallardo <
>>>>>>>>>>>>> Oh, okay. Yeah you're right about it taking time. I wrote a
>>>>>>>>>>>>> python script to generate the raster2pgsql call with the appropriate table
>>>>>>>>>>>>> name, so I can just let it run while I do other things. I really appreciate
>>>>>>>>>>>>> your help on this. I googled your name and I see you're a pretty busy
>>>>>>>>>>>>> person, so I'm glad you're taking the time to answer my questions.
>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 3:05 PM, Bborie Park <
>>>>>>>>>>>>>> No. I'm suggesting it later as it does take time and
>>>>>>>>>>>>>> separates operations. Get everything imported first and then add
>>>>>>>>>>>>>> constraints.
>>>>>>>>>>>>>> Having said that, you can do it all at once if so desired...
>>>>>>>>>>>>>> just preference depending on volume of import data.
>>>>>>>>>>>>>> -bborie
>>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 1:02 PM, Jayson Gallardo <
>>>>>>>>>>>>>>> Okay, is there a specific reason why? As your link states: "
>>>>>>>>>>>>>>> raster2pgsql loader uses this function to register raster
>>>>>>>>>>>>>>> tables". Are you saying I should specify constraints that will be similar
>>>>>>>>>>>>>>> across all tables?
>>>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 2:53 PM, Bborie Park <
>>>>>>>>>>>>>>>> I'd suggest adding constraints after the fact through SQL
>>>>>>>>>>>>>>>> instead of letting raster2pgsql do it.
>>>>>>>>>>>>>>>> http://www.postgis.net/docs/manual-2.0/RT_AddRasterConstraints.html
>>>>>>>>>>>>>>>> -bborie
>>>>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 12:51 PM, Jayson Gallardo <
>>>>>>>>>>>>>>>>> So based on the link you provided, and what else I've
>>>>>>>>>>>>>>>>> gathered, I first create a parent table:
>>>>>>>>>>>>>>>>>  CREATE TABLE dem_elevation
>>>>>>>>>>>>>>>>>   rid integer NOT NULL PRIMARY KEY
>>>>>>>>>>>>>>>>>   rast raster,
>>>>>>>>>>>>>>>>>  Then I run raster2pgsql on all the downloaded elevation
>>>>>>>>>>>>>>>>> data, sending each input tile to its own table, ie. dem_elevation_n36w091.
>>>>>>>>>>>>>>>>> Then alter table to inherit from parent:
>>>>>>>>>>>>>>>>> ALTER TABLE dem_elevation_n36w091 INHERIT dem_elevation;
>>>>>>>>>>>>>>>>> With raster2pgsql taking care of setting the constraints
>>>>>>>>>>>>>>>>> for each table. Now, I can just query the parent table dem_elevation to get
>>>>>>>>>>>>>>>>> what I need?
>>>>>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 2:33 PM, Bborie Park <
>>>>>>>>>>>>>>>>>> I use the USGS NED 10 meter for California with one table
>>>>>>>>>>>>>>>>>> for each input raster. In the partitioned table scheme, data tables inherit
>>>>>>>>>>>>>>>>>> from a template (parent) table. Queries run on the parent table access the
>>>>>>>>>>>>>>>>>> inherited tables.
>>>>>>>>>>>>>>>>>> -bborie
>>>>>>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 11:56 AM, Jayson Gallardo <
>>>>>>>>>>>>>>>>>>> Yes, it's usgs ned. And I initially went with one table
>>>>>>>>>>>>>>>>>>> for each input tile, but I didn't know how to join (or union) them together
>>>>>>>>>>>>>>>>>>> for my query.
>>>>>>>>>>>>>>>>>>>  On Jul 23, 2013 1:14 PM, "Bborie Park" <
>>>>>>>>>>>>>>>>>>>> Can you describe your elevation dataset? Is it USGS
>>>>>>>>>>>>>>>>>>>> NED? At which resolution (10 meter, 3 meter?)?
>>>>>>>>>>>>>>>>>>>> As for table partitioning...
>>>>>>>>>>>>>>>>>>>> http://www.postgresql.org/docs/9.0/static/ddl-partitioning.html
>>>>>>>>>>>>>>>>>>>> You'll probably partition spatially, though an easy
>>>>>>>>>>>>>>>>>>>> solution is to have a table for each input raster file.
>>>>>>>>>>>>>>>>>>>> -bborie
>>>>>>>>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 11:05 AM, Jayson Gallardo <
>>>>>>>>>>>>>>>>>>>>> Thanks for responding. Could you outline how I would
>>>>>>>>>>>>>>>>>>>>> go about doing a partitioned table structure? My only concern with tile
>>>>>>>>>>>>>>>>>>>>> size is processing time. Most of my queries will involve areas of less than
>>>>>>>>>>>>>>>>>>>>> 1 mi^2, and I would clip the data into that shape. I just don't know where
>>>>>>>>>>>>>>>>>>>>> to start! There's not too many resources online/print dealing with postgis
>>>>>>>>>>>>>>>>>>>>> rasters in detail.
>>>>>>>>>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 12:57 PM, Bborie Park <
>>>>>>>>>>>>>>>>>>>>>> You may not need to drop all the constraints when
>>>>>>>>>>>>>>>>>>>>>> adding additional data to the table. You most likely will need to drop is
>>>>>>>>>>>>>>>>>>>>>> the maximum extent constraint. Assuming the input rasters have the same
>>>>>>>>>>>>>>>>>>>>>> scale, skew and SRID as that found in the table, you don't need to drop
>>>>>>>>>>>>>>>>>>>>>> those corresponding constraints.
>>>>>>>>>>>>>>>>>>>>>> If you're going to do the continental US at a fine
>>>>>>>>>>>>>>>>>>>>>> resolution (e.g. 1 meter), you do NOT want to put all the rasters in one
>>>>>>>>>>>>>>>>>>>>>> table. You'll want to use a partitioned table structure and should consider
>>>>>>>>>>>>>>>>>>>>>> a bigger tile size (depending on your hardware).
>>>>>>>>>>>>>>>>>>>>>> -bborie
>>>>>>>>>>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 10:43 AM, Jayson Gallardo <
>>>>>>>>>>>>>>>>>>>>>>> I've looked and looked, but I have not been able to
>>>>>>>>>>>>>>>>>>>>>>> find an answer to my question. I have downloaded elevation data for the
>>>>>>>>>>>>>>>>>>>>>>> state of Arkansas (in the form of multiple tiles), and used raster2pgsql to
>>>>>>>>>>>>>>>>>>>>>>> upload it into a single table:
>>>>>>>>>>>>>>>>>>>>>>> raster2pgsql -I -C -e -F -t 50x50 -l 2,4 n*/grdn*
>>>>>>>>>>>>>>>>>>>>>>> public.dem_elevation | psql -U postgres -d testdb -h localhost -p 5432
>>>>>>>>>>>>>>>>>>>>>>> I did this because I didn't know how to pull the
>>>>>>>>>>>>>>>>>>>>>>> data if they were in separate tables. Now, however I would like to add
>>>>>>>>>>>>>>>>>>>>>>> elevation data for other areas. I tried to just add it to the current
>>>>>>>>>>>>>>>>>>>>>>> table, but that required dropping the constraints which for such a huge
>>>>>>>>>>>>>>>>>>>>>>> amount of data seems to take a long time (I let it run for 24+ hours and it
>>>>>>>>>>>>>>>>>>>>>>> didn't finish). So, my question is, if I load all my rasters as individual
>>>>>>>>>>>>>>>>>>>>>>> tables, how could I run something similar to this query on them all (from a
>>>>>>>>>>>>>>>>>>>>>>> python script):
>>>>>>>>>>>>>>>>>>>>>>> ST_GeomFromText(WKT,900913)),'GTiff') FROM "dem_elevation" WHERE
>>>>>>>>>>>>>>>>>>>>>>> ST_Intersects(rast, ST_Transform(ST_GeomFromText(WKT,900913),4269))
>>>>>>>>>>>>>>>>>>>>>>> My goal, if it's not obvious, is to clip elevation
>>>>>>>>>>>>>>>>>>>>>>> data and export it to a GTiff format and perform some operations on that
>>>>>>>>>>>>>>>>>>>>>>> raster data. Eventually, I would like to put the whole continental US
>>>>>>>>>>>>>>>>>>>>>>> elevation data into my database, so I need to be able to do so, while still
>>>>>>>>>>>>>>>>>>>>>>> being able to query them based on an area of interest the user selects from
>>>>>>>>>>>>>>>>>>>>>>> a map. I started working with PostGIS and Mapserver last month, so please
>>>>>>>>>>>>>>>>>>>>>>> forgive my ignorance on such topics. Thanks in advance
>>>>>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>>>>>> postgis-users mailing list
>>>>>>>>>>>>>>>>>>>>>>> postgis-users at lists.osgeo.org
>>>>>>>>>>>>>>>>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130730/8ee04def/attachment.html>
