[postgis-users] Update data in PostGIS database
Morten Sickel morten at sickel.net
Mon Jun 3 04:41:58 PDT 2013
Ahh, I see. You may still use log-shipping, transfering the xlog-files on
a flash-disk, but it is probably just as easy to do an entire dump/restore
cycle.
(on my servers (running ubunto 1204, I have pg_basebackup, pg_dump,
pg_dumpall and pg_restore which may be usesd - or you may do on the
"master":
cd $POSTGRESDATADIRECTORY
psql -c "SELECT pg_start_backup('label', true)"
rsync -a ${PGDATA}/ $USBDRIVE --exclude postmaster.pid
psql -c "SELECT pg_stop_backup()"
then on the slaves
stop the postgres server
copy the files from the usb into the data directory
start the postgres server
Morten
thomas lechauve skrev:
> Unfortunately, servers cannot communicate. "client" servers are not
> connected to a network, they work in standalone, so i have to use an usb
> drive to transport backup file, then restore it.
> On Mon, Jun 3, 2013 at 1:12 PM, Morten Sickel <morten at sickel.net> wrote:
>> It depends a bit...
>> If those servers are able to communicate with each other on port 5432,
>> you
>> can use streaming replication to make one of the servers being a (read
>> only) mirror of the other. - or you may set up log-shipping streaming
>> replication, in which case te master server only needs to be able to
>> send
>> files (i.e. using rsync) to the slave server.
>> In both cases, the servers must be identical - same versions and the
>> same
>> databases - which all are read only on the slave... (You may of course
>> run
>> more postgres servers on the slave, where one is dedicated to the
>> OSM-data.)
>> Just ask me if you need some assistance, I have set up a few
>> streaming-replication and log-shipping replication servers.
>> Morten
>> > Hello,
>> > I am trying to synchronize two PostGIS databases.
>> > I have a reference server which is filled and updated every day with
>> OSM
>> > data. For this purpose I recreate the whole database. But now i want
>> to
>> > update another database which is not on the same server based on the
>> first
>> > database without recreate it.
>> > pg_dump/pg_restore tools are probably what i am looking for, but i
>> cannot
>> > find a way to achieve my purposes.
>> > Do i have to keep trying with those tools or is there another way ?
>> > Perhaps a SQL script could do it but i want to avoid it because i am
>> no
>> > expert in PostGIS and databases in general.
>> > Any recommendations ?
>> > Cheers
>> > Thomas LECHAUVE
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at lists.osgeo.org
>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> Thomas LECHAUVE
> portable : +33 6 51 21 07 40
> fixe : +33 9 82 37 41 94
