Hello, I'm not sure your query can give you the expected results. To count points from a within polys of b you should try something like Select b.gid, count(*) from a, b Where st_within(a.the_geom, b.the_geom) Group by b.gid Hugues Ps: Nico i'm home :) Raffaele Morelli <raffaele.morelli at gmail.com> a écrit :
