[postgis-users] Raster pixel count too high
Andreas Forø Tollefsen
andreasft at gmail.com
Tue Jun 18 05:59:57 PDT 2013
Hi Kim,
Thanks for your answer. However, we want raster as an output, since we want
to be able to use the summarystats function.
Please elaborate how you think ST_PixelAsPolygons should solve out issue?
Thanks.
Andreas
2013/6/18 Kim Bisgaard <kib at dmi.dk>
> Hi,
> Try to use 'ST_PixelAsPolygons(ST_Clip(n.rast, p.cell))'
> instead of 'ST_Intersects(n.rast, p.cell)'
> Regards,
> Kim
> On 2013-06-18 11:03, Andreas Forø Tollefsen wrote:
> Hi,
> We are working on a raster summarystats script to calculate various
> statistics for the pixels within fishnet polygons.
> Our raster cell size is 0.0083333333333... x 0.0083333333333... degrees
> while our quadrat polygons are 0.5 x 0.5 decimal degrees.
> This should give us 60x60 raster pixels within each of our polygons.
> ArcGIS zonal statistics returns a pixel count of 3600 in addition to other
> statistics.
> However, PostGIS returns 3721 pixel count.
> We do not really understand why, but it seems that our query includes
> some pixels that are outside of the polygon, but still touches the vertices
> of the polygon and are therefore included in the calculation.
> Are there any way of modifying our script to return the same result as
> ArcGIS?
> Thanks!
> Andreas
> script:
> /* This query makes one raster for each PRIO-GRID cell. Clip and union
> is the procedure. */
> INSERT INTO nightlightsprio (gid, "year", rast)
> (SELECT gid, "year", ST_Union(raster) as rast
> FROM
> (SELECT p.gid, n."year", ST_Clip(n.rast, p.cell) as raster
> FROM nightlights n, priogridyear p
> WHERE ST_Intersects(n.rast, p.cell)
> AND n."year" = p."year"
> as priorast
> GROUP BY gid, "year");
> /* Default BandNoDataValue is 0. Raster value 0 means no light, not no
> data. Setting to NULL. This produces correct results. */
> UPDATE nightlightsprio2 SET rast = ST_SetBandNoDataValue(rast, 1, NULL);
> ALTER TABLE nightlightsprio2 ADD COLUMN nightlights_sum double precision,
> ADD COLUMN nightlights_mean double precision,
> ADD COLUMN nightlights_sd double precision,
> ADD COLUMN nightlights_min double precision,
> ADD COLUMN nightlights_max double precision,
> ADD COLUMN nightlights_count integer;
> UPDATE nightlightsprio2 SET nightlights_sum =
> (ST_SummaryStats(rast)).sum;
> UPDATE nightlightsprio2 SET nightlights_mean =
> (ST_SummaryStats(rast)).mean;
> UPDATE nightlightsprio2 SET nightlights_sd =
> (ST_SummaryStats(rast)).stddev;
> UPDATE nightlightsprio2 SET nightlights_min = (ST_SummaryStats(rast)).min;
> UPDATE nightlightsprio2 SET nightlights_max = (ST_SummaryStats(rast)).max;
> UPDATE nightlightsprio2 SET nightlights_count =
> (ST_SummaryStats(rast)).count;
> postgis-users mailing listpostgis-users at lists.osgeo.orghttp://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> Kim Bisgaard
> Application Development Division Phone: +45 3915 7562 (direct)
> Danish Meteorological Institute Fax: +45 3915 7460 (division)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130618/c790e6c4/attachment.html>
