[postgis-users] Newbie having trouble with Multipolygon file	and ST_Within
    Alexandre Neto
    senhor.neto at gmail.com
    Wed Jun 26 02:11:18 PDT 2013
Hello,
I'm not sure why, but that also happens to me sometimes when I see my data
in pgadmin. Nevertheless, like you said, all geometries are shown in GIS,
and it never give me any problems at all.
Take a look at the answer for this question:
http://gis.stackexchange.com/questions/6247/some-objects-missing-after-importing-a-shp-into-postgis
Hope it helps,
Alexandre Neto
On Tue, Jun 25, 2013 at 6:44 PM, willemb <willem at pcfish.ca> wrote:
> I have imported a multipolygon shape file into postgis 2.  When I look at
> the
> table I see that only a few of the areas are showing a value in the
> geometry
> column (geom).  When I run a spatial query using something like st_within
> against another file it seems to only work on the those rows that have a
> geom.  I can't figure out how to populate the missing geometries.  What I
> don't understand is that if I use Manifold or QGIS to view the file from
> postgis all of the areas are present even though the geometries are not
> present for the vast majority of records.  Is there a hidden column?
> Clearly there is something I'm not understanding about Multipolygon files.
> http://postgis.17.x6.nabble.com/Newbie-having-trouble-with-Multipolygon-file-and-ST-Within-tp5003597.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130626/b0fb800c/attachment-0001.html>
