[postgis-users] merging geometries of buffer on large data set
Sitansu pattnaik
sitansu at gmail.com
Sun Jun 30 10:23:37 PDT 2013
Have you thought of using rasters ?
Sitansu
@ kCube
On Sun, Jun 30, 2013 at 10:33 PM, Martin Davis <mtnclimb at telus.net> wrote:
> Hi, Karsten.
> One potential problem with merging all the buffers for a given value is
> that you may wind up with a very large polygon that creates its own
> handling issues.
> If you only need this for analytical purposes, not for display, then it
> might work better to aim for a middle ground. You could merge the buffers
> in "clumps". To do this, you need to partition the buffers into
> spatially-coherent groups. A simple way to do this is to create a grid
> over the area (say based on the coordinate system you are using). Create a
> reprsentative point for each buffer (e.g. the interior point or centroid).
> The buffers can then be assigned to the grid cell their point lies in.
> Then group the buffers by their grid cell, and union each group.
> Actually, if you want to carry on and create single polygons, then the
> clumped buffer polygons give a better basis to work from (since they should
> have many fewer points than the source polygons).
> If there are still memory issues with the clumped unions, then you can
> carry out this process in an iterated fashion, starting with small grid
> cells and then repeating with a larger size. (At this point you will have
> basically reimplemented the GEOS CascadedUnion algorithm. But that's ok -
> performing the algorithm at the SQL level allows more control over memory
> and processing usage).
> I'd be interesting to hear if this approach works out.
> Martin
> On 6/28/2013 5:11 PM, karsten vennemann wrote:
> I was wondering if there is a good (or best practice) approach on how to
> merge geometry features that are touching or overlapping and have one
> common value in one table field.****
> Here is what I was trying to do: given a large dataset such as the
> (detailed NHD data layer) of rivers in California I created multiple
> buffers and inserted the results into a new table with one geometry column
> adding a score value to each of the same buffers distances used. Thus the
> buffer polygon layer has a score with a value of 10,100,500 and 1000 m
> corresponding to the buffer distance used. Given the approach I used to
> create the buffers those are often spatially overlapping (because there was
> no merge operation of the buffers and because the rivers are split along
> the flow line in multiple segments by node in the source shape file). The
> resulting layer works ok for my purposes (which is to retrieve information
> in which buffers a certain location is intersecting it with the river
> buffer (results can be 10,100,500 and 1000 or no intersect with the
> buffers).****
> Now the layers is about 20 GB big disk size having a lot of unnecessary
> geometries with are overlapping.****
> How can I go about merging all the existing geometries on this huge data
> set into a result layer that has (optimally ) only 4 polygons with the
> result scores to find my intersects. ****
> When I tried some of my own approaches (e.g. using st_collect and such to
> do this) so far whenever I started these sever resource intensive
> operations soon these where aborted by the system because i got some kind
> of out of memeonry errosr on my server (an ubuntu achjien). Is there a good
> way to optimize this kind of query operation without using 100% of my
> server ram so that I will not run out of memory or resulting in a lengthy
> query that would be running for 6 weeks or so J ?****
> Any query examples or general insight are greatly appreciated .****
> Cheers****
> Karsten****
> Karsten Vennemann****
> Terra GIS Ltd****
> 2119 Boyer Ave E****
> Seattle, WA 98112****
> USA****
> tel ++ 206 905 1711****
> fax ++ 925 905 1711****
> postgis-users mailing listpostgis-users at lists.osgeo.orghttp://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> No virus found in this message.
> Checked by AVG - www.avg.com
> Version: 2013.0.2904 / Virus Database: 3184/6359 - Release Date: 05/26/13
> Internal Virus Database is out of date.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130630/f8b2f684/attachment.html>
