[postgis-users] Count Points in Polygon with Postgis
Francois Hugues
hugues.francois at irstea.fr
Sat Mar 16 09:42:18 PDT 2013
Sorry read too fast (and made a mistake using st_contains as st_within) !
You should also add an union :
Select poly_id, count(*) as nb_point from
(select distinct poly_id, point_id from table_point, table_poly
Where st_contains(poly_geom, point_geom)
) as foo
Group by poly_id
Union
Select poly_id, 0 from table_point, table_poly
Where not st_contains(poly_geom, point_geom)
Hugues
De : postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] De la part de Francois Hugues
Envoyé : samedi 16 mars 2013 17:35
À : PostGIS Users Discussion
Objet : Re: [postgis-users] Count Points in Polygon with Postgis
Hello,
The following query should work well with your data :
(select poly_id, point_id from table_point, table_poly
Where st_contains(point_geom, poly_geom)
) as foo
Group by poly_id
Hugues.
De : postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] De la part de Carsten Hogertz
Envoyé : samedi 16 mars 2013 16:53
Objet : [postgis-users] Count Points in Polygon with Postgis
I've got a simple problem: I want to count the number of points within a set of polygons.
I have a SQL already but it only gives back the gid of the polygone that actually contains points.
My tables: a polygon layer with 19.000 rows and a point layer with 450 rows.
The following SQL
select grid.gid, count(*) AS totale FROM grid, kioskdhd3 WHERE
st_contains(grid.geom,kioskdhd3.geom) GROUP BY grid.gid;
return only some 320 polygons that actually contain points. But I want all polygons returned, even thought the number of points is 0.
Of course it has to do with my WHERE-clause. Where do I have to put in my st_contains?
Thank you Carsten
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130316/3ddcd876/attachment.html>
