[postgis-users] Count Points in Polygon with Postgis
Stephen Mather mather.stephen at gmail.com
Sat Mar 16 10:47:53 PDT 2013
Try unioning with the opposite condition.
Sent from my iPod
On Mar 16, 2013, at 11:53 AM, Carsten Hogertz <carsten.hogertz at gmail.com> wrote:
> I've got a simple problem: I want to count the number of points within a set of polygons.
> I have a SQL already but it only gives back the gid of the polygone that actually contains points.
> My tables: a polygon layer with 19.000 rows and a point layer with 450 rows.
> The following SQL
> select grid.gid, count(*) AS totale FROM grid, kioskdhd3 WHERE
> st_contains(grid.geom,kioskdhd3.geom) GROUP BY grid.gid;
> return only some 320 polygons that actually contain points. But I want all polygons returned, even thought the number of points is 0.
> Of course it has to do with my WHERE-clause. Where do I have to put in my st_contains?
> Thank you Carsten
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130316/30cdf17e/attachment.html>
