[postgis-users] How to improve query with repeated spatial join query
Alexandre Neto
senhor.neto at gmail.com
Fri May 3 03:51:43 PDT 2013
Hi, thanks for your help.
On Fri, May 3, 2013 at 11:31 AM, Jo <winfixit at gmail.com> wrote:
> As far as I understand SQL, it's normal you repeat clauses. I'm pretty
> sure the optimizer takes care of that and they are not actually executed
> more than once.
Using EXPLAIN, it says that it will repeat the a Nested Loop to check the
ST_CONTAIN
> Maybe indexes on the ST_Centroid functions would help?
For that, do Ihave to "materialize" the point geometry in my table, and
create a index?
> Where do g.geom and f.geom come from?
My mistake, I tried to adapt the query a bit to make it more obvious here,
and forgot those two. It should be ST_CONTAIN(p.geom, ST_CENTROID(b.geom))
> Jo
> 2013/5/3 Alexandre Neto <senhor.neto at gmail.com>
>> Hello all,
>> My goal is to calculate for each building it's volume
>> percentage relatively to the total buildings volume inside the statistical
>> parcel he is in.
>> I have written the SQL code below (that works), but I think it might be
>> improved, since I see repeated proceedings in it.
>> I would greatly appreciate if someone give me some advice about it.
>> Thanks,
>> Alexandre Neto
>> SELECT
>> b.gid,
>> b.volume / t.total_volume as vol_per,
>> b.geom,
>> p.bgri11 as bgri11,
>> FROM
>> buildings as b,
>> stat_parcels as p,
>> (SELECT
>> sum(b.volume) as total_volume,
>> p.bgri11 as bgri11
>> FROM
>> buildings as b,
>> stat_parcels as p
>> WHERE
>> ST_CONTAINS(p.geom, St_centroid(b.geom))
>> GROUP BY
>> p.bgri11) as t
>> WHERE
>> ST_CONTAINS(g.geom, St_centroid(f.geom))
>> AND p.bgri11 = t.bgri11;
>> My tables look like this:
>> CREATE TABLE buildings
>> gid serial NOT NULL,
>> volume double precision,
>> geom geometry(MultiPolygon,27493),
>> CONSTRAINT edificios_habitacao_pkey PRIMARY KEY (gid);
>> CREATE TABLE stat_parcels
>> bgri11 character varying(11),
>> CONSTRAINT bgri11_cascais_pkey PRIMARY KEY (gid)
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130503/f51caccb/attachment.html>
