[postgis-users] Need a method for "noding" a street network
Nicolas Ribot
nicolas.ribot at gmail.com
Wed May 8 11:39:59 PDT 2013
Hi Stephen,
Building a topology would definitively help in this situation, though it
may take some time on very large dataset I guess.
If you plan to use some topological functions on the dataset in addition
with pgRouting functions, it may be worth the effort.
Concerning st_union and its magic "segmentize" feature, would it be
possible to divide the initial set of lines into smaller areas and process
these subsets to avoid filling up the memory ?
Looking at this subject recently (cutting lines by points, cf.
http://trac.osgeo.org/postgis/wiki/UsersWikiSplitPolygonWithPoints) I found
that linear referencing functions can help in such a case.
The principle is to get the location index of intersection points for each
line, and then to cut this line by its locations, using st_line_substring.
It appears to be very efficient, using st_dwithin to trigger spatial index,
then joining on the lines primary keys, which should be fast.
In your usecase, intersection nodes between lines have to be identified
before their locations can be computed.
Concerning the tolerance, I'm pretty sure snapping the input dataset to a
grid would help to run a precise st_intersection between lines.
Based on the linestring sample data, here is the query using linear
referencing. It uses CTE subqueries to identify each step:
with lines as (
select 1 as gid, 'MULTILINESTRING((0 1,2 1))'::geometry as geom
union all
select 2 as gid, 'MULTILINESTRING((1 0,1 2))'::geometry as geom
union all
select 3 as gid, 'LINESTRING(1 1.5,2 2)'::geometry as geom
-- multilinestrings are dumped into simple objects
-- if multilinestrings have several parts, one should generate a unique id
based
-- on their gid and path into the collection.
dumped_lines as (
select gid, (st_dump(l.geom)).geom
from lines l
-- This query computes the locations, for each input line, of the
intersection points with other lines.
-- this will be used to cut lines based on these locations.
-- to be able to cut lines from their beginning to their end, we generate
the 0 and 1 location index
cut_locations as (
select l1.gid as lgid, st_line_locate_point(l1.geom,
st_intersection(l1.geom, l2.geom)) as locus
from dumped_lines l1 join dumped_lines l2 on (st_dwithin(l1.geom, l2.geom,
0.01))
where l1.gid <> l2.gid
-- then generates start and end locus for each line, to be able to cut them
UNION ALL
select l.gid as lgid, 0 as locus
from dumped_lines l
UNION ALL
select l.gid as lgid, 1 as locus
from dumped_lines l
order by lgid, locus
-- This query generates a row_number index column for each input line and
intersection point.
-- This index will be used to self-join the table to cut a line between two
consecutive locations
-- (idx, idx+1) pairs.
-- window function is used to generate the index inside each line partition
loc_with_idx as (
select lgid, locus, row_number() over (partition by lgid order by locus) as
idx
from cut_locations
-- finally, each original line is cut with consecutive locations using
linear referencing function.
-- a filtering is done to eliminate points produced when lines connect at
their ends
select l.gid, loc1.idx as sub_id, st_line_substring(l.geom, loc1.locus,
loc2.locus) as geom ,
st_geometryType(st_line_substring(l.geom, loc1.locus, loc2.locus)) as type
from loc_with_idx loc1 join loc_with_idx loc2 using (lgid) join
dumped_lines l on (l.gid = loc1.lgid)
where loc2.idx = loc1.idx+1
-- filter out point geometries occuring if intersection point is at line's
start or end point.
-- there must be a faster way to filter out theses geometries.
and st_geometryType(st_line_substring(l.geom, loc1.locus, loc2.locus)) <>
'ST_Point';
A new unique ID key can be computed based on line gid and subgid generated
by the query.
Initial line attributes can be moved to the new segments using the line gid
key.
Nicolas
On 8 May 2013 16:27, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> Hi all,
> This question comes up reasonably often on the pgRouting list and has been
> posted he on occasion under titles like "How to break streets at
> intersections?"
> It seems to me that this would be a good function to create in either
> postgis or pgrouting.
> THE PROBLEM:
> I have a table of 10's of thousands of street segments to 10's of millions
> of street segments. These street segments are LINSTRING or MULTILINESTRING
> geometries with some arbitrary number of attribute columns. The geometries
> may cross one another and are not noded correctly for use with pgRouting.
> THE RESULTS:
> We want to process the table and create a new table with the same
> structure (see comment about primary key below), and in the new table all
> the geometries are broken at intersections and all the new pieces of the
> original segment that have been broken have the original attributes
> propagated to them. So if the original segment has column foo='abc' and was
> split into 3 new segments, each of the three new segments would also have
> foo='abc'. The exception to this might be that the new table needs a new
> primary column as the old primary key will now be duplicated for the
> multiple parts.
> POTENTIAL SOLUTIONS:
> 1. I think one way to do this would be to create a topology and load the
> table into it, then extra a new table from the topology. Although I'm not
> sure of the specifics for doing this or the efficency of doing it this way.
> 2. Another way seems to be using a query like:
> select (st_dump(bar.the_geom)).* from (
> select st_union(foo.the_geom) as the_geom from mytable foo
> ) as bar;
> And then taking each of the dump.geom objects and using st_contains to
> find which original segment it belonged to so we can move the attributes to
> the new segment. This method also loose any association to the original
> record and forces the use of st_contains to re-associate the new segments
> to the original segments.
> My concern with this is that the st_union has to load the whole table
> which may be 10's of millions of street segments and this will likely be a
> memory problem. Also running the st_contains() does not seems to me to be
> optimal.
> 3. Is there a good recipe for doing this somewhere that I have not found?
> or other better approaches to this problem?
> What would be the best way to add tolerance to the problem? using snap to
> grid?
> Thoughts on how to do this efficiently?
> Since I'm working on the pgRouting 2.0 release I thought this might be a
> nice function to add to that if we can come up with a generic way to do
> this.
> Thanks,
> -Steve
> -- Example to demonstrate st_union above
> select st_astext((st_dump(bar.the_**geom)).geom) from (
> select st_union(foo.the_geom) as the_geom from (
> select 'MULTILINESTRING((0 1,2 1))'::geometry as the_geom
> union all
> select 'MULTILINESTRING((1 0,1 2))'::geometry as the_geom
> union all
> select 'LINESTRING(1 1.5,2 2)'::geometry as the_geom
> ) as foo
> ) as bar;
> "LINESTRING(1 1.5,2 2)"
> "LINESTRING(1 0,1 1)"
> "LINESTRING(1 1,1 1.5)"
> "LINESTRING(1 1.5,1 2)"
> "LINESTRING(0 1,1 1)"
> "LINESTRING(1 1,2 1)"
> ______________________________**_________________
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-**bin/mailman/listinfo/postgis-**users<http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130508/cf065af1/attachment.html>
