[postgis-users] Need a method for "noding" a street network
Nicolas Ribot
nicolas.ribot at gmail.com
Wed May 8 13:04:13 PDT 2013
On 8 May 2013 21:50, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> I tried to change my first with to just query and existing table, like:
> with lines as (
> select id as gid, * from bdaways
> select 1 as gid, 'MULTILINESTRING((0 1,2 1))'::geometry as geom
> union all
> select 2 as gid, 'MULTILINESTRING((1 0,1 2))'::geometry as geom
> union all
> select 3 as gid, 'LINESTRING(1 1.5,2 2)'::geometry as geom
> but when I run it I get:
> ERROR: line_locate_point: 2st arg isnt a point
> ********** Error **********
> SQL state: XX000
> This looks like st_intersection(l1.geom, l2.geom) is not returning a point.
Yes it may return an empty geometryCollection. It could be filtered in the
cut_locations cte by adding a where clause geometryType = 'POINT'.
> On 5/8/2013 3:32 PM, Nicolas Ribot wrote:
>> Hi,
>> Glad it helps.
>> CTE are supported since 8.4 according to the doc:
>> http://www.postgresql.org/**docs/8.4/static/queries-with.**html<http://www.postgresql.org/docs/8.4/static/queries-with.html>
> ok, cool, will give that a try also.
> Otherwise, the CTE's can be replaced by subqueries.
>> The stored procedure may also help by creating temp tables instead of
>> chaining subqueries, though I don't know if it will run faster.
> One thing I noticed is that CTE's can not be indexed, so I might get
> better performance is I create tables and index them based on the needs of
> successive queries in a stored procedure. I'll need to play with this a bit
> to figure out what works best.
> Using topology should be pretty simple in your case: build a new
>> topology based on the lines table, then query the topology.edge table,
>> keeping initial line gid. It may be worth trying it.
> I need to find the how to for working with topologies. I have seem some in
> the past and just need to give it a try now that I have a real use case for
> it.
> -Steve
> Nicolas
>> On 8 May 2013 21:01, Stephen Woodbridge <woodbri at swoodbridge.com
>> <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>> wrote:
>> Hi Nicolas,
>> Wow! thank you for an excellent example. This is very help. Since I
>> want this to work on pg 8.4+, I'll convert this into a stored
>> procedure since I can't use CTE subqueries.
>> Now I have some work cut out to do on this. :)
>> Thanks again,
>> -Steve
>> On 5/8/2013 2:39 PM, Nicolas Ribot wrote:
>> Hi Stephen,
>> Building a topology would definitively help in this situation,
>> though it
>> may take some time on very large dataset I guess.
>> If you plan to use some topological functions on the dataset in
>> addition
>> with pgRouting functions, it may be worth the effort.
>> Concerning st_union and its magic "segmentize" feature, would it
>> be
>> possible to divide the initial set of lines into smaller areas and
>> process these subsets to avoid filling up the memory ?
>> Looking at this subject recently (cutting lines by points, cf.
>> http://trac.osgeo.org/postgis/**__wiki/__**
>> UsersWikiSplitPolygonWithPoint**__s<http://trac.osgeo.org/postgis/__wiki/__UsersWikiSplitPolygonWithPoint__s>
>> <http://trac.osgeo.org/**postgis/wiki/**
>> UsersWikiSplitPolygonWithPoint**s<http://trac.osgeo.org/postgis/wiki/UsersWikiSplitPolygonWithPoints>
>> I
>> found that linear referencing functions can help in such a case.
>> The principle is to get the location index of intersection
>> points for
>> each line, and then to cut this line by its locations, using
>> st_line_substring.
>> It appears to be very efficient, using st_dwithin to trigger
>> spatial
>> index, then joining on the lines primary keys, which should be
>> fast.
>> In your usecase, intersection nodes between lines have to be
>> identified
>> before their locations can be computed.
>> Concerning the tolerance, I'm pretty sure snapping the input
>> dataset to
>> a grid would help to run a precise st_intersection between lines.
>> Based on the linestring sample data, here is the query using
>> linear
>> referencing. It uses CTE subqueries to identify each step:
>> with lines as (
>> union all
>> union all
>> geom
>> -- multilinestrings are dumped into simple objects
>> -- if multilinestrings have several parts, one should generate a
>> unique
>> id based
>> -- on their gid and path into the collection.
>> dumped_lines as (
>> select gid, (st_dump(l.geom)).geom
>> from lines l
>> -- This query computes the locations, for each input line, of the
>> intersection points with other lines.
>> -- this will be used to cut lines based on these locations.
>> -- to be able to cut lines from their beginning to their end, we
>> generate the 0 and 1 location index
>> cut_locations as (
>> select l1.gid as lgid, st_line_locate_point(l1.geom,
>> st_intersection(l1.geom, l2.geom)) as locus
>> from dumped_lines l1 join dumped_lines l2 on (st_dwithin(l1.geom,
>> l2.geom, 0.01))
>> where l1.gid <> l2.gid
>> -- then generates start and end locus for each line, to be able
>> to cut them
>> UNION ALL
>> select l.gid as lgid, 0 as locus
>> from dumped_lines l
>> UNION ALL
>> select l.gid as lgid, 1 as locus
>> from dumped_lines l
>> order by lgid, locus
>> -- This query generates a row_number index column for each input
>> line
>> and intersection point.
>> -- This index will be used to self-join the table to cut a line
>> between
>> two consecutive locations
>> -- (idx, idx+1) pairs.
>> -- window function is used to generate the index inside each
>> line partition
>> loc_with_idx as (
>> select lgid, locus, row_number() over (partition by lgid order
>> by locus)
>> as idx
>> from cut_locations
>> -- finally, each original line is cut with consecutive locations
>> using
>> linear referencing function.
>> -- a filtering is done to eliminate points produced when lines
>> connect
>> at their ends
>> select l.gid, loc1.idx as sub_id, st_line_substring(l.geom,
>> loc1.locus,
>> loc2.locus) as geom ,
>> st_geometryType(st_line___**substring(l.geom, loc1.locus,
>> loc2.locus)) as type
>> from loc_with_idx loc1 join loc_with_idx loc2 using (lgid) join
>> dumped_lines l on (l.gid = loc1.lgid)
>> where loc2.idx = loc1.idx+1
>> -- filter out point geometries occuring if intersection point is
>> at
>> line's start or end point.
>> -- there must be a faster way to filter out theses geometries.
>> and st_geometryType(st_line___**substring(l.geom, loc1.locus,
>> loc2.locus))
>> <> 'ST_Point';
>> A new unique ID key can be computed based on line gid and subgid
>> generated by the query.
>> Initial line attributes can be moved to the new segments using
>> the line
>> gid key.
>> Nicolas
>> On 8 May 2013 16:27, Stephen Woodbridge <woodbri at swoodbridge.com
>> <mailto:woodbri at swoodbridge.__**com
>> <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>
>> wrote:
>> Hi all,
>> This question comes up reasonably often on the pgRouting
>> list and
>> has been posted he on occasion under titles like "How to
>> break
>> streets at intersections?"
>> It seems to me that this would be a good function to create
>> in
>> either postgis or pgrouting.
>> THE PROBLEM:
>> I have a table of 10's of thousands of street segments to
>> 10's of
>> millions of street segments. These street segments are
>> LINSTRING or
>> MULTILINESTRING geometries with some arbitrary number of
>> attribute
>> columns. The geometries may cross one another and are not
>> noded
>> correctly for use with pgRouting.
>> THE RESULTS:
>> We want to process the table and create a new table with
>> the same
>> structure (see comment about primary key below), and in the
>> new
>> table all the geometries are broken at intersections and
>> all the new
>> pieces of the original segment that have been broken have the
>> original attributes propagated to them. So if the original
>> segment
>> has column foo='abc' and was split into 3 new segments,
>> each of the
>> three new segments would also have foo='abc'. The exception
>> to this
>> might be that the new table needs a new primary column as
>> the old
>> primary key will now be duplicated for the multiple parts.
>> POTENTIAL SOLUTIONS:
>> 1. I think one way to do this would be to create a topology
>> and load
>> the table into it, then extra a new table from the topology.
>> Although I'm not sure of the specifics for doing this or the
>> efficency of doing it this way.
>> 2. Another way seems to be using a query like:
>> select (st_dump(bar.the_geom)).* from (
>> select st_union(foo.the_geom) as the_geom from mytable
>> foo
>> ) as bar;
>> And then taking each of the dump.geom objects and using
>> st_contains
>> to find which original segment it belonged to so we can
>> move the
>> attributes to the new segment. This method also loose any
>> association to the original record and forces the use of
>> st_contains
>> to re-associate the new segments to the original segments.
>> My concern with this is that the st_union has to load the
>> whole
>> table which may be 10's of millions of street segments and
>> this will
>> likely be a memory problem. Also running the st_contains()
>> does not
>> seems to me to be optimal.
>> 3. Is there a good recipe for doing this somewhere that I
>> have not
>> found? or other better approaches to this problem?
>> What would be the best way to add tolerance to the problem?
>> using
>> snap to grid?
>> Thoughts on how to do this efficiently?
>> Since I'm working on the pgRouting 2.0 release I thought
>> this might
>> be a nice function to add to that if we can come up with a
>> generic
>> way to do this.
>> Thanks,
>> -Steve
>> -- Example to demonstrate st_union above
>> select st_astext((st_dump(bar.the____**_geom)).geom) from (
>> select st_union(foo.the_geom) as the_geom from (
>> select 'MULTILINESTRING((0 1,2 1))'::geometry as
>> the_geom
>> union all
>> select 'MULTILINESTRING((1 0,1 2))'::geometry as
>> the_geom
>> union all
>> select 'LINESTRING(1 1.5,2 2)'::geometry as the_geom
>> ) as foo
>> ) as bar;
>> "LINESTRING(1 1.5,2 2)"
>> "LINESTRING(1 0,1 1)"
>> "LINESTRING(1 1,1 1.5)"
>> "LINESTRING(1 1.5,1 2)"
>> "LINESTRING(0 1,1 1)"
>> "LINESTRING(1 1,2 1)"
>> ______________________________**_____________________
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> <mailto:postgis-users at lists.**osgeo.org<postgis-users at lists.osgeo.org>
>> <mailto:postgis-users at lists.__**osgeo.org <http://osgeo.org>
>> http://lists.osgeo.org/cgi-___**_bin/mailman/listinfo/postgis-**
>> ____users<http://lists.osgeo.org/cgi-____bin/mailman/listinfo/postgis-____users>
>> <http://lists.osgeo.org/cgi-__**bin/mailman/listinfo/postgis-_**
>> _users<http://lists.osgeo.org/cgi-__bin/mailman/listinfo/postgis-__users>
>> <http://lists.osgeo.org/cgi-**bin/mailman/listinfo/postgis-**
>> users <http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users>>>
>> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.**
>> osgeo.org <postgis-users at lists.osgeo.org>>
>> _users<http://lists.osgeo.org/cgi-__bin/mailman/listinfo/postgis-__users><
>> http://lists.osgeo.org/cgi-**bin/mailman/listinfo/postgis-**users<http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users>
>> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.**osgeo.org<postgis-users at lists.osgeo.org>
>> http://lists.osgeo.org/cgi-__**bin/mailman/listinfo/postgis-_**_users<http://lists.osgeo.org/cgi-__bin/mailman/listinfo/postgis-__users>
>> <http://lists.osgeo.org/cgi-**bin/mailman/listinfo/postgis-**users<http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130508/169a9b98/attachment.html>
