[postgis-users] Need a method for "noding" a street network
Stephen Woodbridge woodbri at swoodbridge.com
Wed May 8 12:50:38 PDT 2013
I tried to change my first with to just query and existing table, like:
with lines as (
	select id as gid, * from bdaways
         select 1 as gid, 'MULTILINESTRING((0 1,2 1))'::geometry as geom
         union all
         select 2 as gid, 'MULTILINESTRING((1 0,1 2))'::geometry as geom
         union all
         select 3 as gid, 'LINESTRING(1 1.5,2 2)'::geometry as geom
but when I run it I get:
ERROR:  line_locate_point: 2st arg isnt a point
********** Error **********
SQL state: XX000
This looks like st_intersection(l1.geom, l2.geom) is not returning a point.
On 5/8/2013 3:32 PM, Nicolas Ribot wrote:
> Hi,
> Glad it helps.
> CTE are supported since 8.4 according to the doc:
> http://www.postgresql.org/docs/8.4/static/queries-with.html
ok, cool, will give that a try also.
> Otherwise, the CTE's can be replaced by subqueries.
> The stored procedure may also help by creating temp tables instead of
> chaining subqueries, though I don't know if it will run faster.
One thing I noticed is that CTE's can not be indexed, so I might get
better performance is I create tables and index them based on the needs
of successive queries in a stored procedure. I'll need to play with this
a bit to figure out what works best.
> Using topology should be pretty simple in your case: build a new
> topology based on the lines table, then query the topology.edge table,
> keeping initial line gid. It may be worth trying it.
I need to find the how to for working with topologies. I have seem some
in the past and just need to give it a try now that I have a real use
case for it.
-Steve
> Nicolas
> On 8 May 2013 21:01, Stephen Woodbridge <woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>> wrote:
>     Hi Nicolas,
>     Wow! thank you for an excellent example. This is very help. Since I
>     want this to work on pg 8.4+, I'll convert this into a stored
>     procedure since I can't use CTE subqueries.
>     Now I have some work cut out to do on this. :)
>     Thanks again,
>        -Steve
>     On 5/8/2013 2:39 PM, Nicolas Ribot wrote:
>         Hi Stephen,
>         Building a topology would definitively help in this situation,
>         though it
>         may take some time on very large dataset I guess.
>         If you plan to use some topological functions on the dataset in
>         addition
>         with pgRouting functions, it may be worth the effort.
>         Concerning st_union and its magic "segmentize" feature, would it be
>         possible to divide the initial set of lines into smaller areas and
>         process these subsets to avoid filling up the memory ?
>         Looking at this subject recently (cutting lines by points, cf.
>         http://trac.osgeo.org/postgis/__wiki/__UsersWikiSplitPolygonWithPoint__s
>         <http://trac.osgeo.org/postgis/wiki/UsersWikiSplitPolygonWithPoints>)
>         I
>         found that linear referencing functions can help in such a case.
>         The principle is to get the location index of intersection
>         points for
>         each line, and then to cut this line by its locations, using
>         st_line_substring.
>         It appears to be very efficient, using st_dwithin to trigger spatial
>         index, then joining on the lines primary keys, which should be fast.
>         In your usecase, intersection nodes between lines have to be
>         identified
>         before their locations can be computed.
>         Concerning the tolerance, I'm pretty sure snapping the input
>         dataset to
>         a grid would help to run a precise st_intersection between lines.
>         Based on the linestring sample data, here is  the query using linear
>         referencing. It uses CTE subqueries to identify each step:
>         with lines as (
>                   union all
>                   union all
>         -- multilinestrings are dumped into simple objects
>         -- if multilinestrings have several parts, one should generate a
>         unique
>         id based
>         -- on their gid and path into the collection.
>         dumped_lines as (
>         select gid, (st_dump(l.geom)).geom
>         from lines l
>         -- This query computes the locations, for each input line, of the
>         intersection points with other lines.
>         -- this will be used to cut lines based on these locations.
>         -- to be able to cut lines from their beginning to their end, we
>         generate the 0 and 1 location index
>         cut_locations as (
>         select l1.gid as lgid, st_line_locate_point(l1.geom,
>         st_intersection(l1.geom, l2.geom)) as locus
>         from dumped_lines l1 join dumped_lines l2 on (st_dwithin(l1.geom,
>         l2.geom, 0.01))
>         where l1.gid <> l2.gid
>         -- then generates start and end locus for each line, to be able
>         to cut them
>         UNION ALL
>         select l.gid as lgid, 0 as locus
>         from dumped_lines l
>         UNION ALL
>         select l.gid as lgid, 1 as locus
>         from dumped_lines l
>         order by lgid, locus
>         -- This query generates a row_number index column for each input
>         line
>         and intersection point.
>         -- This index will be used to self-join the table to cut a line
>         between
>         two consecutive locations
>         -- (idx, idx+1) pairs.
>         -- window function is used to generate the index inside each
>         line partition
>         loc_with_idx as (
>         select lgid, locus, row_number() over (partition by lgid order
>         by locus)
>         as idx
>         from cut_locations
>         -- finally, each original line is cut with consecutive locations
>         using
>         linear referencing function.
>         -- a filtering is done to eliminate points produced when lines
>         connect
>         at their ends
>         select l.gid, loc1.idx as sub_id, st_line_substring(l.geom,
>         loc1.locus,
>         loc2.locus) as geom ,
>         st_geometryType(st_line___substring(l.geom, loc1.locus,
>         loc2.locus)) as type
>         from loc_with_idx loc1 join loc_with_idx loc2 using (lgid) join
>         dumped_lines l on (l.gid = loc1.lgid)
>         where loc2.idx = loc1.idx+1
>         -- filter out point geometries occuring if intersection point is at
>         line's start or end point.
>         -- there must be a faster way to filter out theses geometries.
>         and st_geometryType(st_line___substring(l.geom, loc1.locus,
>         loc2.locus))
>         <> 'ST_Point';
>         A new unique ID key can be computed based on line gid and subgid
>         generated by the query.
>         Initial line attributes can be moved to the new segments using
>         the line
>         gid key.
>         Nicolas
>         On 8 May 2013 16:27, Stephen Woodbridge <woodbri at swoodbridge.com
>         <mailto:woodbri at swoodbridge.__com
>         <mailto:woodbri at swoodbridge.com>>> wrote:
>              Hi all,
>              This question comes up reasonably often on the pgRouting
>         list and
>              has been posted he on occasion under titles like "How to break
>              streets at intersections?"
>              It seems to me that this would be a good function to create in
>              either postgis or pgrouting.
>              THE PROBLEM:
>              I have a table of 10's of thousands of street segments to
>         10's of
>              millions of street segments. These street segments are
>         LINSTRING or
>              MULTILINESTRING geometries with some arbitrary number of
>         attribute
>              columns. The geometries may cross one another and are not noded
>              correctly for use with pgRouting.
>              THE RESULTS:
>              We want to process the table and create a new table with
>         the same
>              structure (see comment about primary key below), and in the new
>              table all the geometries are broken at intersections and
>         all the new
>              pieces of the original segment that have been broken have the
>              original attributes propagated to them. So if the original
>         segment
>              has column foo='abc' and was split into 3 new segments,
>         each of the
>              three new segments would also have foo='abc'. The exception
>         to this
>              might be that the new table needs a new primary column as
>         the old
>              primary key will now be duplicated for the multiple parts.
>              POTENTIAL SOLUTIONS:
>              1. I think one way to do this would be to create a topology
>         and load
>              the table into it, then extra a new table from the topology.
>              Although I'm not sure of the specifics for doing this or the
>              efficency of doing it this way.
>              2. Another way seems to be using a query like:
>              select (st_dump(bar.the_geom)).* from (
>                   select st_union(foo.the_geom) as the_geom from mytable foo
>              ) as bar;
>              And then taking each of the dump.geom objects and using
>         st_contains
>              to find which original segment it belonged to so we can
>         move the
>              attributes to the new segment. This method also loose any
>              association to the original record and forces the use of
>         st_contains
>              to re-associate the new segments to the original segments.
>              My concern with this is that the st_union has to load the whole
>              table which may be 10's of millions of street segments and
>         this will
>              likely be a memory problem. Also running the st_contains()
>         does not
>              seems to me to be optimal.
>              3. Is there a good recipe for doing this somewhere that I
>         have not
>              found? or other better approaches to this problem?
>              What would be the best way to add tolerance to the problem?
>         using
>              snap to grid?
>              Thoughts on how to do this efficiently?
>              Since I'm working on the pgRouting 2.0 release I thought
>         this might
>              be a nice function to add to that if we can come up with a
>         generic
>              way to do this.
>              Thanks,
>                 -Steve
>              -- Example to demonstrate st_union above
>              select st_astext((st_dump(bar.the_____geom)).geom) from (
>                   select st_union(foo.the_geom) as the_geom from (
>                       select 'MULTILINESTRING((0 1,2 1))'::geometry as
>         the_geom
>                       union all
>                       select 'MULTILINESTRING((1 0,1 2))'::geometry as
>         the_geom
>                       union all
>                       select 'LINESTRING(1 1.5,2 2)'::geometry as the_geom
>                       ) as foo
>                   ) as bar;
>              "LINESTRING(1 1.5,2 2)"
>              "LINESTRING(1 0,1 1)"
>              "LINESTRING(1 1,1 1.5)"
>              "LINESTRING(1 1.5,1 2)"
>              "LINESTRING(0 1,1 1)"
>              "LINESTRING(1 1,2 1)"
>              ___________________________________________________
>              postgis-users mailing list
>         postgis-users at lists.osgeo.org
>         <mailto:postgis-users at lists.osgeo.org>
>         <mailto:postgis-users at lists.__osgeo.org
>         <mailto:postgis-users at lists.osgeo.org>>
>         http://lists.osgeo.org/cgi-____bin/mailman/listinfo/postgis-____users
>         <http://lists.osgeo.org/cgi-__bin/mailman/listinfo/postgis-__users>
>         <http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users>>
>         postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
>         http://lists.osgeo.org/cgi-__bin/mailman/listinfo/postgis-__users <http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users>
