[postgis-users] Need a method for "noding" a street network
Stephen Woodbridge
woodbri at swoodbridge.com
Wed May 8 13:50:47 PDT 2013
On 5/8/2013 4:05 PM, Nicolas Ribot wrote:
> Is it possible for you to share the dataset or a subset of it, to give
> it a try ?
http://imaptools.com:8081/dl/test1.sql.gz
This dataset was noded to start with if that matter, I added the geom
column and populated it from the x1, y1, x2, y2 columns. So it is not a
real test in the sense of noding it but it is a typical sized smaller
data set that we have to deal with.
I added the where and my query is running, so I'll report back what
happens with it.
Thanks,
-Steve
> Nicolas
> On 8 May 2013 22:04, Nicolas Ribot <nicolas.ribot at gmail.com
> <mailto:nicolas.ribot at gmail.com>> wrote:
> On 8 May 2013 21:50, Stephen Woodbridge <woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>> wrote:
> I tried to change my first with to just query and existing
> table, like:
> with lines as (
> select id as gid, * from bdaways
> select 1 as gid, 'MULTILINESTRING((0 1,2 1))'::geometry
> as geom
> union all
> select 2 as gid, 'MULTILINESTRING((1 0,1 2))'::geometry
> as geom
> union all
> select 3 as gid, 'LINESTRING(1 1.5,2 2)'::geometry as geom
> but when I run it I get:
> ERROR: line_locate_point: 2st arg isnt a point
> ********** Error **********
> SQL state: XX000
> This looks like st_intersection(l1.geom, l2.geom) is not
> returning a point.
> Yes it may return an empty geometryCollection. It could be filtered
> in the cut_locations cte by adding a where clause geometryType =
> 'POINT'.
> On 5/8/2013 3:32 PM, Nicolas Ribot wrote:
> Hi,
> Glad it helps.
> CTE are supported since 8.4 according to the doc:
> http://www.postgresql.org/__docs/8.4/static/queries-with.__html
> <http://www.postgresql.org/docs/8.4/static/queries-with.html>
> ok, cool, will give that a try also.
> Otherwise, the CTE's can be replaced by subqueries.
> The stored procedure may also help by creating temp tables
> instead of
> chaining subqueries, though I don't know if it will run faster.
> One thing I noticed is that CTE's can not be indexed, so I might
> get better performance is I create tables and index them based
> on the needs of successive queries in a stored procedure. I'll
> need to play with this a bit to figure out what works best.
> Using topology should be pretty simple in your case: build a new
> topology based on the lines table, then query the
> topology.edge table,
> keeping initial line gid. It may be worth trying it.
> I need to find the how to for working with topologies. I have
> seem some in the past and just need to give it a try now that I
> have a real use case for it.
> -Steve
> Nicolas
> On 8 May 2013 21:01, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>
> <mailto:woodbri at swoodbridge.__com
> <mailto:woodbri at swoodbridge.com>>> wrote:
> Hi Nicolas,
> Wow! thank you for an excellent example. This is very
> help. Since I
> want this to work on pg 8.4+, I'll convert this into a
> stored
> procedure since I can't use CTE subqueries.
> Now I have some work cut out to do on this. :)
> Thanks again,
> -Steve
> On 5/8/2013 2:39 PM, Nicolas Ribot wrote:
> Hi Stephen,
> Building a topology would definitively help in this
> situation,
> though it
> may take some time on very large dataset I guess.
> If you plan to use some topological functions on
> the dataset in
> addition
> with pgRouting functions, it may be worth the effort.
> Concerning st_union and its magic "segmentize"
> feature, would it be
> possible to divide the initial set of lines into
> smaller areas and
> process these subsets to avoid filling up the memory ?
> Looking at this subject recently (cutting lines by
> points, cf.
> http://trac.osgeo.org/postgis/____wiki/____UsersWikiSplitPolygonWithPoint____s
> <http://trac.osgeo.org/postgis/__wiki/__UsersWikiSplitPolygonWithPoint__s>
> <http://trac.osgeo.org/__postgis/wiki/__UsersWikiSplitPolygonWithPoint__s
> <http://trac.osgeo.org/postgis/wiki/UsersWikiSplitPolygonWithPoints>>)
> I
> found that linear referencing functions can help in
> such a case.
> The principle is to get the location index of
> intersection
> points for
> each line, and then to cut this line by its
> locations, using
> st_line_substring.
> It appears to be very efficient, using st_dwithin
> to trigger spatial
> index, then joining on the lines primary keys,
> which should be fast.
> In your usecase, intersection nodes between lines
> have to be
> identified
> before their locations can be computed.
> Concerning the tolerance, I'm pretty sure snapping
> the input
> dataset to
> a grid would help to run a precise st_intersection
> between lines.
> Based on the linestring sample data, here is the
> query using linear
> referencing. It uses CTE subqueries to identify
> each step:
> with lines as (
> 1))'::geometry as geom
> union all
> 2))'::geometry as geom
> union all
> -- multilinestrings are dumped into simple objects
> -- if multilinestrings have several parts, one
> should generate a
> unique
> id based
> -- on their gid and path into the collection.
> dumped_lines as (
> select gid, (st_dump(l.geom)).geom
> from lines l
> -- This query computes the locations, for each
> input line, of the
> intersection points with other lines.
> -- this will be used to cut lines based on these
> locations.
> -- to be able to cut lines from their beginning to
> their end, we
> generate the 0 and 1 location index
> cut_locations as (
> select l1.gid as lgid, st_line_locate_point(l1.geom,
> st_intersection(l1.geom, l2.geom)) as locus
> from dumped_lines l1 join dumped_lines l2 on
> (st_dwithin(l1.geom,
> l2.geom, 0.01))
> where l1.gid <> l2.gid
> -- then generates start and end locus for each
> line, to be able
> to cut them
> UNION ALL
> select l.gid as lgid, 0 as locus
> from dumped_lines l
> UNION ALL
> select l.gid as lgid, 1 as locus
> from dumped_lines l
> order by lgid, locus
> -- This query generates a row_number index column
> for each input
> line
> and intersection point.
> -- This index will be used to self-join the table
> to cut a line
> between
> two consecutive locations
> -- (idx, idx+1) pairs.
> -- window function is used to generate the index
> inside each
> line partition
> loc_with_idx as (
> select lgid, locus, row_number() over (partition by
> lgid order
> by locus)
> as idx
> from cut_locations
> -- finally, each original line is cut with
> using
> linear referencing function.
> -- a filtering is done to eliminate points produced
> when lines
> connect
> at their ends
> select l.gid, loc1.idx as sub_id,
> st_line_substring(l.geom,
> loc1.locus,
> loc2.locus) as geom ,
> st_geometryType(st_line_____substring(l.geom,
> loc1.locus,
> loc2.locus)) as type
> from loc_with_idx loc1 join loc_with_idx loc2 using
> (lgid) join
> dumped_lines l on (l.gid = loc1.lgid)
> where loc2.idx = loc1.idx+1
> -- filter out point geometries occuring if
> intersection point is at
> line's start or end point.
> -- there must be a faster way to filter out theses
> geometries.
> and st_geometryType(st_line_____substring(l.geom,
> loc1.locus,
> loc2.locus))
> <> 'ST_Point';
> A new unique ID key can be computed based on line
> gid and subgid
> generated by the query.
> Initial line attributes can be moved to the new
> segments using
> the line
> gid key.
> Nicolas
> On 8 May 2013 16:27, Stephen Woodbridge
> <mailto:woodbri at swoodbridge.>____com
> <mailto:woodbri at swoodbridge.com>>>> wrote:
> Hi all,
> This question comes up reasonably often on the
> pgRouting
> list and
> has been posted he on occasion under titles
> like "How to break
> streets at intersections?"
> It seems to me that this would be a good
> function to create in
> either postgis or pgrouting.
> THE PROBLEM:
> I have a table of 10's of thousands of street
> segments to
> 10's of
> millions of street segments. These street
> segments are
> LINSTRING or
> MULTILINESTRING geometries with some arbitrary
> number of
> attribute
> columns. The geometries may cross one another
> and are not noded
> correctly for use with pgRouting.
> THE RESULTS:
> We want to process the table and create a new
> table with
> the same
> structure (see comment about primary key
> below), and in the new
> table all the geometries are broken at
> intersections and
> all the new
> pieces of the original segment that have been
> broken have the
> original attributes propagated to them. So if
> the original
> segment
> has column foo='abc' and was split into 3 new
> segments,
> each of the
> three new segments would also have foo='abc'.
> The exception
> to this
> might be that the new table needs a new
> primary column as
> the old
> primary key will now be duplicated for the
> multiple parts.
> POTENTIAL SOLUTIONS:
> 1. I think one way to do this would be to
> create a topology
> and load
> the table into it, then extra a new table from
> the topology.
> Although I'm not sure of the specifics for
> doing this or the
> efficency of doing it this way.
> 2. Another way seems to be using a query like:
> select (st_dump(bar.the_geom)).* from (
> select st_union(foo.the_geom) as the_geom
> from mytable foo
> ) as bar;
> And then taking each of the dump.geom objects
> and using
> st_contains
> to find which original segment it belonged to
> so we can
> move the
> attributes to the new segment. This method
> also loose any
> association to the original record and forces
> the use of
> st_contains
> to re-associate the new segments to the
> original segments.
> My concern with this is that the st_union has
> to load the whole
> table which may be 10's of millions of street
> segments and
> this will
> likely be a memory problem. Also running the
> st_contains()
> does not
> seems to me to be optimal.
> 3. Is there a good recipe for doing this
> somewhere that I
> have not
> found? or other better approaches to this problem?
> What would be the best way to add tolerance to
> the problem?
> using
> snap to grid?
> Thoughts on how to do this efficiently?
> Since I'm working on the pgRouting 2.0 release
> I thought
> this might
> be a nice function to add to that if we can
> come up with a
> generic
> way to do this.
> Thanks,
> -Steve
> -- Example to demonstrate st_union above
> select
> st_astext((st_dump(bar.the_______geom)).geom) from (
> from (
> select 'MULTILINESTRING((0 1,2
> 1))'::geometry as
> the_geom
> union all
> select 'MULTILINESTRING((1 0,1
> 2))'::geometry as
> the_geom
> union all
> select 'LINESTRING(1 1.5,2
> 2)'::geometry as the_geom
> ) as foo
> ) as bar;
> "LINESTRING(1 1.5,2 2)"
> "LINESTRING(1 0,1 1)"
> "LINESTRING(1 1,1 1.5)"
> "LINESTRING(1 1.5,1 2)"
> "LINESTRING(0 1,1 1)"
> "LINESTRING(1 1,2 1)"
> _____________________________________________________
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> <mailto:postgis-users at lists.osgeo.org>
> <mailto:postgis-users at lists.__osgeo.org
> <mailto:postgis-users at lists.osgeo.org>>
> <mailto:postgis-users at lists.>____osgeo.org <http://osgeo.org>
> <mailto:postgis-users at lists.osgeo.org>>>
> http://lists.osgeo.org/cgi-______bin/mailman/listinfo/postgis-______users
> <http://lists.osgeo.org/cgi-____bin/mailman/listinfo/postgis-____users>
> <http://lists.osgeo.org/cgi-__bin/mailman/listinfo/postgis-__users>>
> <http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users>>>
> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> http://lists.osgeo.org/cgi-__bin/mailman/listinfo/postgis-__users <http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users>
