[postgis-users] Need a method for "noding" a street network
    Stephen Woodbridge
    woodbri at swoodbridge.com
    Wed May  8 14:05:47 PDT 2013
Nicolas,
My query just finished running:
Total query runtime: 3716995 ms.
38079 rows retrieved.
Since I started with 17268 rows, I guess I need to rerun this and dump
the results into a new table so I can look at them. Evidently my table
was not noded as I thought.
I'm running:
"PostgreSQL 9.2.4 on i686-pc-linux-gnu, compiled by gcc-4.4.real (Debian
4.4.5-8) 4.4.5, 32-bit"
"POSTGIS="2.0.3 r11128" GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel. 4.7.1, 23
September 2009" GDAL="GDAL 1.6.3, released 2009/11/19" LIBXML="2.7.8"
RASTER"
on a very old and slow system with minimal memory, so an 1+ hr probably
is not horrid, but I don't have anything to compare that against.
-Steve
On 5/8/2013 4:50 PM, Stephen Woodbridge wrote:
> On 5/8/2013 4:05 PM, Nicolas Ribot wrote:
>> Is it possible for you to share the dataset or a subset of it, to give
>> it a try ?
> http://imaptools.com:8081/dl/test1.sql.gz
> This dataset was noded to start with if that matter, I added the geom
> column and populated it from the x1, y1, x2, y2 columns. So it is not a
> real test in the sense of noding it but it is a typical sized smaller
> data set that we have to deal with.
> I added the where and my query is running, so I'll report back what
> happens with it.
> Thanks,
>    -Steve
>> Nicolas
>> On 8 May 2013 22:04, Nicolas Ribot <nicolas.ribot at gmail.com
>> <mailto:nicolas.ribot at gmail.com>> wrote:
>>     On 8 May 2013 21:50, Stephen Woodbridge <woodbri at swoodbridge.com
>>     <mailto:woodbri at swoodbridge.com>> wrote:
>>         I tried to change my first with to just query and existing
>>         table, like:
>>         with lines as (
>>                  select id as gid, * from bdaways
>>                  select 1 as gid, 'MULTILINESTRING((0 1,2 1))'::geometry
>>         as geom
>>                  union all
>>                  select 2 as gid, 'MULTILINESTRING((1 0,1 2))'::geometry
>>         as geom
>>                  union all
>>                  select 3 as gid, 'LINESTRING(1 1.5,2 2)'::geometry as
>> geom
>>         but when I run it I get:
>>         ERROR:  line_locate_point: 2st arg isnt a point
>>         ********** Error **********
>>         SQL state: XX000
>>         This looks like st_intersection(l1.geom, l2.geom) is not
>>         returning a point.
>>     Yes it may return an empty geometryCollection. It could be filtered
>>     in the cut_locations cte by adding a where clause geometryType =
>>     'POINT'.
>>         On 5/8/2013 3:32 PM, Nicolas Ribot wrote:
>>             Hi,
>>             Glad it helps.
>>             CTE are supported since 8.4 according to the doc:
>> http://www.postgresql.org/__docs/8.4/static/queries-with.__html
>>             <http://www.postgresql.org/docs/8.4/static/queries-with.html>
>>         ok, cool, will give that a try also.
>>             Otherwise, the CTE's can be replaced by subqueries.
>>             The stored procedure may also help by creating temp tables
>>             instead of
>>             chaining subqueries, though I don't know if it will run
>> faster.
>>         One thing I noticed is that CTE's can not be indexed, so I might
>>         get better performance is I create tables and index them based
>>         on the needs of successive queries in a stored procedure. I'll
>>         need to play with this a bit to figure out what works best.
>>             Using topology should be pretty simple in your case: build
>> a new
>>             topology based on the lines table, then query the
>>             topology.edge table,
>>             keeping initial line gid. It may be worth trying it.
>>         I need to find the how to for working with topologies. I have
>>         seem some in the past and just need to give it a try now that I
>>         have a real use case for it.
>>         -Steve
>>             Nicolas
>>             On 8 May 2013 21:01, Stephen Woodbridge
>>             <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>
>>             <mailto:woodbri at swoodbridge.__com
>>             <mailto:woodbri at swoodbridge.com>>> wrote:
>>                  Hi Nicolas,
>>                  Wow! thank you for an excellent example. This is very
>>             help. Since I
>>                  want this to work on pg 8.4+, I'll convert this into a
>>             stored
>>                  procedure since I can't use CTE subqueries.
>>                  Now I have some work cut out to do on this. :)
>>                  Thanks again,
>>                     -Steve
>>                  On 5/8/2013 2:39 PM, Nicolas Ribot wrote:
>>                      Hi Stephen,
>>                      Building a topology would definitively help in this
>>             situation,
>>                      though it
>>                      may take some time on very large dataset I guess.
>>                      If you plan to use some topological functions on
>>             the dataset in
>>                      addition
>>                      with pgRouting functions, it may be worth the
>> effort.
>>                      Concerning st_union and its magic "segmentize"
>>             feature, would it be
>>                      possible to divide the initial set of lines into
>>             smaller areas and
>>                      process these subsets to avoid filling up the
>> memory ?
>>                      Looking at this subject recently (cutting lines by
>>             points, cf.
>> http://trac.osgeo.org/postgis/____wiki/____UsersWikiSplitPolygonWithPoint____s
>> <http://trac.osgeo.org/postgis/__wiki/__UsersWikiSplitPolygonWithPoint__s>
>> <http://trac.osgeo.org/__postgis/wiki/__UsersWikiSplitPolygonWithPoint__s
>> <http://trac.osgeo.org/postgis/wiki/UsersWikiSplitPolygonWithPoints>>)
>>                      I
>>                      found that linear referencing functions can help in
>>             such a case.
>>                      The principle is to get the location index of
>>             intersection
>>                      points for
>>                      each line, and then to cut this line by its
>>             locations, using
>>                      st_line_substring.
>>                      It appears to be very efficient, using st_dwithin
>>             to trigger spatial
>>                      index, then joining on the lines primary keys,
>>             which should be fast.
>>                      In your usecase, intersection nodes between lines
>>             have to be
>>                      identified
>>                      before their locations can be computed.
>>                      Concerning the tolerance, I'm pretty sure snapping
>>             the input
>>                      dataset to
>>                      a grid would help to run a precise st_intersection
>>             between lines.
>>                      Based on the linestring sample data, here is  the
>>             query using linear
>>                      referencing. It uses CTE subqueries to identify
>>             each step:
>>                      with lines as (
>>                      1))'::geometry as geom
>>                                union all
>>                      2))'::geometry as geom
>>                                union all
>>             2)'::geometry as geom
>>                      -- multilinestrings are dumped into simple objects
>>                      -- if multilinestrings have several parts, one
>>             should generate a
>>                      unique
>>                      id based
>>                      -- on their gid and path into the collection.
>>                      dumped_lines as (
>>                      select gid, (st_dump(l.geom)).geom
>>                      from lines l
>>                      -- This query computes the locations, for each
>>             input line, of the
>>                      intersection points with other lines.
>>                      -- this will be used to cut lines based on these
>>             locations.
>>                      -- to be able to cut lines from their beginning to
>>             their end, we
>>                      generate the 0 and 1 location index
>>                      cut_locations as (
>>                      select l1.gid as lgid, st_line_locate_point(l1.geom,
>>                      st_intersection(l1.geom, l2.geom)) as locus
>>                      from dumped_lines l1 join dumped_lines l2 on
>>             (st_dwithin(l1.geom,
>>                      l2.geom, 0.01))
>>                      where l1.gid <> l2.gid
>>                      -- then generates start and end locus for each
>>             line, to be able
>>                      to cut them
>>                      UNION ALL
>>                      select l.gid as lgid, 0 as locus
>>                      from dumped_lines l
>>                      UNION ALL
>>                      select l.gid as lgid, 1 as locus
>>                      from dumped_lines l
>>                      order by lgid, locus
>>                      -- This query generates a row_number index column
>>             for each input
>>                      line
>>                      and intersection point.
>>                      -- This index will be used to self-join the table
>>             to cut a line
>>                      between
>>                      two consecutive locations
>>                      -- (idx, idx+1) pairs.
>>                      -- window function is used to generate the index
>>             inside each
>>                      line partition
>>                      loc_with_idx as (
>>                      select lgid, locus, row_number() over (partition by
>>             lgid order
>>                      by locus)
>>                      as idx
>>                      from cut_locations
>>                      -- finally, each original line is cut with
>>                      using
>>                      linear referencing function.
>>                      -- a filtering is done to eliminate points produced
>>             when lines
>>                      connect
>>                      at their ends
>>                      select l.gid, loc1.idx as sub_id,
>>             st_line_substring(l.geom,
>>                      loc1.locus,
>>                      loc2.locus) as geom ,
>>                      st_geometryType(st_line_____substring(l.geom,
>>             loc1.locus,
>>                      loc2.locus)) as type
>>                      from loc_with_idx loc1 join loc_with_idx loc2 using
>>             (lgid) join
>>                      dumped_lines l on (l.gid = loc1.lgid)
>>                      where loc2.idx = loc1.idx+1
>>                      -- filter out point geometries occuring if
>>             intersection point is at
>>                      line's start or end point.
>>                      -- there must be a faster way to filter out theses
>>             geometries.
>>                      and st_geometryType(st_line_____substring(l.geom,
>>             loc1.locus,
>>                      loc2.locus))
>>                      <> 'ST_Point';
>>                      A new unique ID key can be computed based on line
>>             gid and subgid
>>                      generated by the query.
>>                      Initial line attributes can be moved to the new
>>             segments using
>>                      the line
>>                      gid key.
>>                      Nicolas
>>                      On 8 May 2013 16:27, Stephen Woodbridge
>>             <mailto:woodbri at swoodbridge.>____com
>>             <mailto:woodbri at swoodbridge.com>>>> wrote:
>>                           Hi all,
>>                           This question comes up reasonably often on the
>>             pgRouting
>>                      list and
>>                           has been posted he on occasion under titles
>>             like "How to break
>>                           streets at intersections?"
>>                           It seems to me that this would be a good
>>             function to create in
>>                           either postgis or pgrouting.
>>                           THE PROBLEM:
>>                           I have a table of 10's of thousands of street
>>             segments to
>>                      10's of
>>                           millions of street segments. These street
>>             segments are
>>                      LINSTRING or
>>                           MULTILINESTRING geometries with some arbitrary
>>             number of
>>                      attribute
>>                           columns. The geometries may cross one another
>>             and are not noded
>>                           correctly for use with pgRouting.
>>                           THE RESULTS:
>>                           We want to process the table and create a new
>>             table with
>>                      the same
>>                           structure (see comment about primary key
>>             below), and in the new
>>                           table all the geometries are broken at
>>             intersections and
>>                      all the new
>>                           pieces of the original segment that have been
>>             broken have the
>>                           original attributes propagated to them. So if
>>             the original
>>                      segment
>>                           has column foo='abc' and was split into 3 new
>>             segments,
>>                      each of the
>>                           three new segments would also have foo='abc'.
>>             The exception
>>                      to this
>>                           might be that the new table needs a new
>>             primary column as
>>                      the old
>>                           primary key will now be duplicated for the
>>             multiple parts.
>>                           POTENTIAL SOLUTIONS:
>>                           1. I think one way to do this would be to
>>             create a topology
>>                      and load
>>                           the table into it, then extra a new table from
>>             the topology.
>>                           Although I'm not sure of the specifics for
>>             doing this or the
>>                           efficency of doing it this way.
>>                           2. Another way seems to be using a query like:
>>                           select (st_dump(bar.the_geom)).* from (
>>                                select st_union(foo.the_geom) as the_geom
>>             from mytable foo
>>                           ) as bar;
>>                           And then taking each of the dump.geom objects
>>             and using
>>                      st_contains
>>                           to find which original segment it belonged to
>>             so we can
>>                      move the
>>                           attributes to the new segment. This method
>>             also loose any
>>                           association to the original record and forces
>>             the use of
>>                      st_contains
>>                           to re-associate the new segments to the
>>             original segments.
>>                           My concern with this is that the st_union has
>>             to load the whole
>>                           table which may be 10's of millions of street
>>             segments and
>>                      this will
>>                           likely be a memory problem. Also running the
>>             st_contains()
>>                      does not
>>                           seems to me to be optimal.
>>                           3. Is there a good recipe for doing this
>>             somewhere that I
>>                      have not
>>                           found? or other better approaches to this
>> problem?
>>                           What would be the best way to add tolerance to
>>             the problem?
>>                      using
>>                           snap to grid?
>>                           Thoughts on how to do this efficiently?
>>                           Since I'm working on the pgRouting 2.0 release
>>             I thought
>>                      this might
>>                           be a nice function to add to that if we can
>>             come up with a
>>                      generic
>>                           way to do this.
>>                           Thanks,
>>                              -Steve
>>                           -- Example to demonstrate st_union above
>>                           select
>>             st_astext((st_dump(bar.the_______geom)).geom) from (
>>             from (
>>                                    select 'MULTILINESTRING((0 1,2
>>             1))'::geometry as
>>                      the_geom
>>                                    union all
>>                                    select 'MULTILINESTRING((1 0,1
>>             2))'::geometry as
>>                      the_geom
>>                                    union all
>>                                    select 'LINESTRING(1 1.5,2
>>             2)'::geometry as the_geom
>>                                    ) as foo
>>                                ) as bar;
>>                           "LINESTRING(1 1.5,2 2)"
>>                           "LINESTRING(1 0,1 1)"
>>                           "LINESTRING(1 1,1 1.5)"
>>                           "LINESTRING(1 1.5,1 2)"
>>                           "LINESTRING(0 1,1 1)"
>>                           "LINESTRING(1 1,2 1)"
>>               _____________________________________________________
>>                           postgis-users mailing list
>>             postgis-users at lists.osgeo.org
>>             <mailto:postgis-users at lists.osgeo.org>
>>                      <mailto:postgis-users at lists.__osgeo.org
>>             <mailto:postgis-users at lists.osgeo.org>>
>>             <mailto:postgis-users at lists.>____osgeo.org <http://osgeo.org>
>>             <mailto:postgis-users at lists.osgeo.org>>>
>> http://lists.osgeo.org/cgi-______bin/mailman/listinfo/postgis-______users
>> <http://lists.osgeo.org/cgi-____bin/mailman/listinfo/postgis-____users>
>> <http://lists.osgeo.org/cgi-__bin/mailman/listinfo/postgis-__users>>
>> <http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users>>>
