[postgis-users] Google Directions -> PostGIS
James David Smith james.david.smith at gmail.com
Thu May 16 11:47:29 PDT 2013
Hi there,
I wasn't aware that was against the terms and conditions. Thanks for the
tip.
I've therefore had a look around and found this open source alternative. So
same question as above, but please consider this instead of Google! :-)
Thanks
James
On 16 May 2013 17:05, Travis Kirstine <traviskirstine at gmail.com> wrote:
> I don't think this would be permitted based on Google's terms of service,
> for example:
> Section 10.1.3 *Restrictions against Data Export or Copying.*
> (b) *No Pre-Fetching, Caching, or Storage of Content.* You must not
> pre-fetch, cache, or store any Content, except that you may store: (i)
> limited amounts of Content for the purpose of improving the performance of
> your Maps API Implementation if you do so temporarily (and in no event for
> more than 30 calendar days), securely, and in a manner that does not permit
> use of the Content outside of the Service; and (ii) any content identifier
> or key that the Maps APIs Documentation specifically permits you to store.
> For example, you must not use the Content to create an independent database
> of "places" or other local listings information.
> On 16 May 2013 11:01, James David Smith <james.david.smith at gmail.com>wrote:
>> Hi there,
>> This isn't so much a question as such, more a request for opinions and
>> advice. I was wondering whether anyone had any experience with using the
>> Google API for getting driving directions/routing - but then storing the
>> results in a PostgreSQL/PostGIS database. I was thinking that my workflow
>> might go something like this:
>> 1) Take table of trip_ids, start points, end points, travel modes and
>> start times from the database
>> 2) Export them as a CSV
>> 3) Import the CSV to R
>> 4) Use R to loop through the data and send queries off to the Google API.
>> 5) The results are a series of polylines each with the geometry as a
>> polyline, the length of the stage, the time of the stage etc. As a JSON
>> file. If I could break this apart in it's constiuent parts, could I then
>> store it back in my PostGIS database?
>> I guess the hardest bit I can see about this process, is converting the
>> google encoded polyline to a PostGIS polyline I think. Any thoughts on that?
>> Once this is all done I then want to use the routes with another layer to
>> calculate someones exposure to X over each journey.
>> Any general thoughts about this process would be welcome.
>> Thanks
>> James
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130516/fe0ba2fc/attachment.html>
