[postgis-users] Getting argument of AND must not return a set, when trying to calculate the intersection of a end of a multiline and a polygon
    Dave Potts
    dave.potts at pinan.co.uk
    Thu May 16 16:05:35 PDT 2013
I am trying to find the results of an intersection between a multi line
string and a polygon,  I had assumed that saying something
like
select rt.source,
av.geom,st_astext(st_startpoint((st_dump((rt.the_geom))).geom)) from
route_table rt ,
avoid_areas av
where av.valid=true and rt.parent_port_id=80360 and
st_within(av.geom,st_startpoint((st_dump((rt.the_geom))).geom)) =true
might work where rt.the_geom is a multiline  and av.geom is a polygon
but I get the error,
ERROR:  argument of AND must not return a set
LINE 4: st_within(av.geom,st_startpoint((st_dump((rt.the_geom))).geo
any idea what I am doing wrong?
Dave
