[postgis-users] Getting argument of AND must not return a set, when trying to calculate the intersection of a end of a multiline and a polygon
Dave Potts
dave.potts at pinan.co.uk
Thu May 16 16:23:10 PDT 2013
On 17/05/13 00:05, Dave Potts wrote:
Found a different
solution select count(*) from route_table rt ,
avoid_areas av
where av.valid=true and rt.parent_port_id=80360 and
st_intersects(av.geom,((rt.the_geom))) =false
will answer the same question.
but I would still like to known why I get that error
D.
> Hi,
> I am trying to find the results of an intersection between a multi
> line string and a polygon, I had assumed that saying something
> like
> select rt.source,
> av.geom,st_astext(st_startpoint((st_dump((rt.the_geom))).geom)) from
> route_table rt ,
> avoid_areas av
> st_within(av.geom,st_startpoint((st_dump((rt.the_geom))).geom)) =true
> might work where rt.the_geom is a multiline and av.geom is a polygon
> but I get the error,
> ERROR: argument of AND must not return a set
> LINE 4: st_within(av.geom,st_startpoint((st_dump((rt.the_geom))).geo
> any idea what I am doing wrong?
> Dave
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
