[postgis-users] Getting argument of AND must not return a set, when trying to calculate the intersection of a end of a multiline and a polygon
Stephen Woodbridge woodbri at swoodbridge.com
Thu May 16 18:22:57 PDT 2013
Dave,
st_dump returns a set.
you might want to use st_geometryN(rt.the_geom, 1) instead.
-Steve
On 5/16/2013 7:05 PM, Dave Potts wrote:
> Hi,
> I am trying to find the results of an intersection between a multi line
> string and a polygon,  I had assumed that saying something
> like
> select rt.source,
> av.geom,st_astext(st_startpoint((st_dump((rt.the_geom))).geom)) from
> route_table rt ,
> avoid_areas av
> where av.valid=true and rt.parent_port_id=80360 and
> st_within(av.geom,st_startpoint((st_dump((rt.the_geom))).geom)) =true
> might work where rt.the_geom is a multiline  and av.geom is a polygon
> but I get the error,
> ERROR:  argument of AND must not return a set
> LINE 4: st_within(av.geom,st_startpoint((st_dump((rt.the_geom))).geo
> any idea what I am doing wrong?
> Dave
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
