[postgis-users] 2.1.0beta3dev upgrade error
Bborie Park
dustymugs at gmail.com
Thu May 23 07:00:46 PDT 2013
Steve,
Which version of the json library are you using?
http://trac.osgeo.org/postgis/ticket/2213
-bborie
On Wed, May 22, 2013 at 10:22 PM, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
> Some more data points. I also created a new database and tried:
> pgis21=# create extension postgis;
> ERROR: could not load library "/usr/lib/postgresql/9.2/lib/postgis-2.1.so":
> /usr/lib/postgresql/9.2/lib/postgis-2.1.so: undefined symbol:
> json_tokener_errors
> pgis21=# create extension postgis version '2.0.3';
> "/usr/lib/postgresql/9.2/lib/rtpostgis-2.0.so": libgdal1.6.0.so.1: cannot
> open shared object file: No such file or directory
> So I rebuilt postgis 2.0.3 to use the new gdal that I installed for 2.1 and
> tried "create extension postgis;" and this installed 2.0.3 by default.
> pgis21=# drop extension postgis ;
> DROP EXTENSION
> pgis21=# create extension postgis version '2.1.0beta3dev';
> CREATE EXTENSION
> and now it loaded 2.1 ok.
> Not sure what caused the strangeness, but it seems to be working there, but
> when I run my pgrouting test script:
> woodbri at maps:~/work/pgrouting$ tools/test-runner.pl
> RUNNING: test-runner.pl
> ERROR: could not load library "/usr/lib/postgresql/9.2/lib/postgis-2.0.so":
> /usr/lib/postgresql/9.2/lib/postgis-2.0.so: undefined symbol:
> json_tokener_errors
> ERROR: required extension "postgis" is not installed
> This creates a new database, adds postgis and pgrouting and then runs tests
> in that database.
> -Steve
> On 5/23/2013 1:01 AM, Stephen Woodbridge wrote:
>> Hi all,
>> I just tried to upgrade postgis from 2.0.3 -> 2.1.0beta3dev and got the
>> following error:
>> pgr_test=# alter extension postgis update to '2.1.0beta3dev';
>> json_tokener_errors
>> Did I forget a step or do something wrong?
>> -Steve
>> I have json-c-0.11 built and installed. In fact is is the ./configure
>> report:
>> PostGIS is now configured for i686-pc-linux-gnu
>> -------------- Compiler Info -------------
>> C compiler: gcc -g -O2
>> C++ compiler: g++ -g -O2
>> SQL preprocessor: /usr/bin/cpp -traditional-cpp -P
>> -------------- Dependencies --------------
>> GEOS config: /usr/local/bin/geos-config
>> GEOS version: 3.3.8
>> GDAL config: /usr/local/bin/gdal-config
>> GDAL version: 1.9.2
>> PostgreSQL config: /usr/lib/postgresql/9.2/bin/pg_config
>> PostgreSQL version: PostgreSQL 9.2.4
>> PROJ4 version: 47
>> Libxml2 config: /usr/bin/xml2-config
>> Libxml2 version: 2.7.8
>> JSON-C support: yes
>> PostGIS debug level: 0
>> Perl: /usr/bin/perl
>> --------------- Extensions ---------------
>> PostGIS Raster: enabled
>> PostGIS Topology: enabled
>> SFCGAL support: disabled
>> -------- Documentation Generation --------
>> xsltproc: /usr/bin/xsltproc
>> xsl style sheets:
>> dblatex:
>> convert:
>> mathml2.dtd: http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
