[postgis-users] 2.1.0beta3dev upgrade error
Stephen Woodbridge woodbri at swoodbridge.com
Thu May 23 08:10:11 PDT 2013
Bborie,
I downloaded: json-c-0.11-nodoc.tar.gz
there was also v 0.10 available.
I will also note that json-c does not appear to be available in the
Debian Squeeze repository.
Also, I just noticed the note that I need GEOS 3.4 for the Delauney
triangles, so I'm rebuilding the latest GEOS nightly snapshot and will
install that.
Thanks,
   -Steve
On 5/23/2013 10:00 AM, Bborie Park wrote:
> Steve,
> Which version of the json library are you using?
> http://trac.osgeo.org/postgis/ticket/2213
> -bborie
> On Wed, May 22, 2013 at 10:22 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com> wrote:
>> Some more data points. I also created a new database and tried:
>> pgis21=# create extension postgis;
>> ERROR:  could not load library "/usr/lib/postgresql/9.2/lib/postgis-2.1.so":
>> /usr/lib/postgresql/9.2/lib/postgis-2.1.so: undefined symbol:
>> json_tokener_errors
>> pgis21=# create extension postgis version '2.0.3';
>> "/usr/lib/postgresql/9.2/lib/rtpostgis-2.0.so": libgdal1.6.0.so.1: cannot
>> open shared object file: No such file or directory
>> So I rebuilt postgis 2.0.3 to use the new gdal that I installed for 2.1 and
>> tried "create extension postgis;" and this installed 2.0.3 by default.
>> pgis21=# drop extension postgis ;
>> DROP EXTENSION
>> pgis21=# create extension postgis version '2.1.0beta3dev';
>> CREATE EXTENSION
>> and now it loaded 2.1 ok.
>> Not sure what caused the strangeness, but it seems to be working there, but
>> when I run my pgrouting test script:
>> woodbri at maps:~/work/pgrouting$ tools/test-runner.pl
>> RUNNING: test-runner.pl
>> ERROR:  could not load library "/usr/lib/postgresql/9.2/lib/postgis-2.0.so":
>> /usr/lib/postgresql/9.2/lib/postgis-2.0.so: undefined symbol:
>> json_tokener_errors
>> ERROR:  required extension "postgis" is not installed
>> This creates a new database, adds postgis and pgrouting and then runs tests
>> in that database.
>> -Steve
>> On 5/23/2013 1:01 AM, Stephen Woodbridge wrote:
>>> Hi all,
>>> I just tried to upgrade postgis from 2.0.3 -> 2.1.0beta3dev and got the
>>> following error:
>>> pgr_test=# alter extension postgis update to '2.1.0beta3dev';
>>> json_tokener_errors
>>> Did I forget a step or do something wrong?
>>> -Steve
>>> I have json-c-0.11 built and installed. In fact is is the ./configure
>>> report:
>>>     PostGIS is now configured for i686-pc-linux-gnu
>>>    -------------- Compiler Info -------------
>>>     C compiler:           gcc -g -O2
>>>     C++ compiler:         g++ -g -O2
>>>     SQL preprocessor:     /usr/bin/cpp -traditional-cpp -P
>>>    -------------- Dependencies --------------
>>>     GEOS config:          /usr/local/bin/geos-config
>>>     GEOS version:         3.3.8
>>>     GDAL config:          /usr/local/bin/gdal-config
>>>     GDAL version:         1.9.2
>>>     PostgreSQL config:    /usr/lib/postgresql/9.2/bin/pg_config
>>>     PostgreSQL version:   PostgreSQL 9.2.4
>>>     PROJ4 version:        47
>>>     Libxml2 config:       /usr/bin/xml2-config
>>>     Libxml2 version:      2.7.8
>>>     JSON-C support:       yes
>>>     PostGIS debug level:  0
>>>     Perl:                 /usr/bin/perl
>>>    --------------- Extensions ---------------
>>>     PostGIS Raster:       enabled
>>>     PostGIS Topology:     enabled
>>>     SFCGAL support:       disabled
>>>    -------- Documentation Generation --------
>>>     xsltproc:             /usr/bin/xsltproc
>>>     xsl style sheets:
>>>     dblatex:
>>>     convert:
>>>     mathml2.dtd:          http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
