[postgis-users] st_band with out-db raster data
Bborie Park
dustymugs at gmail.com
Fri Nov 1 07:37:55 PDT 2013
Can you elaborate on what you mean by "return path data"? If ST_Band is
used on a raster band that is out-db, the new raster returned will have a
band that is also out-db.
Are you trying to make out-db in-db?
-bborie
On Fri, Nov 1, 2013 at 7:18 AM, Dilley, Andrew-P57500 <
Andrew.Dilley at gdc4s.com> wrote:
> When using out-db raster data, st_band appears to return path data for
> the raster file rather than a raster. Is that intentional?****
> andy****
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131101/47417d5c/attachment.html>
