[postgis-users] st_band with out-db raster data
Mateusz Loskot
mateusz at loskot.net
Fri Nov 1 07:44:29 PDT 2013
On 1 November 2013 14:18, Dilley, Andrew-P57500 <Andrew.Dilley at gdc4s.com> wrote:
> When using out-db raster data, st_band appears to return path data for the
> raster file rather than a raster. Is that intentional?
You may want to check the "[raster] Paths local to server" thread here
http://lists.osgeo.org/pipermail/postgis-devel/2013-February/023252.html
and related ticket http://trac.osgeo.org/postgis/ticket/2217
It should clarify the semantic of out-db raster.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
