[postgis-users] st_band with out-db raster data
Dilley, Andrew-P57500 Andrew.Dilley at gdc4s.com
Fri Nov 1 09:22:37 PDT 2013
Ok, thanks for the explanation.
andy
-----Original Message-----
From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Mateusz Loskot
Sent: Friday, November 01, 2013 11:40 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] st_band with out-db raster data
On 1 November 2013 15:10, Dilley, Andrew-P57500 <Andrew.Dilley at gdc4s.com> wrote:
> From that thread,
> "We need to do away with the entire in-db and out-db notion and just return the pixel values."
> I guess this is what I mean.  Should st_band be doing this?
I understand this is not easy to follow the thread and the comments posted to the #2217 ticket. However, the conclusion you can draw from those discussions is that the raster WKB format as well as the default behaviour of basic API does not change - PostGIS raster keeps to return server path
http://trac.osgeo.org/postgis/ticket/2217#comment:23
The WKB format is currently defined (version 0) is unable to properly handle out-db raster bands for clients.
Hence, there is related ticket that adds extra parameter to override default behaviour of the APIs
http://trac.osgeo.org/postgis/ticket/2222
I'm not a heavy user of out-db rasters, but I *perhaps* there are other APIs like ST_Band, that should be updated according as ST_Binary has been changed as result of the #2222 ticket.
Anyway, I'm just trying to explain you the current situation, but I'll leave the decisions about API changes to Pierre and Bborie.
> (I'm admittedly very new to postgis so maybe this a stupid question).
IMO, no question is stupid.
Best regards,
Mateusz  Loskot, http://mateusz.loskot.net _______________________________________________
postgis-users mailing list
postgis-users at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
