[postgis-users] st_band with out-db raster data
dustymugs
dustymugs at gmail.com
Fri Nov 1 09:38:21 PDT 2013
I don't believe ST_Band or most functions will have the outasin flag added. ST_AsBinary is for exporting rasters from PostGIS unlike ST_Band which creates a new raster within PostGIS.
If anything, a function that converts an out-db band to in-db band may be useful.
-bborie
-----Original Message-----
Sender: postgis-users-bounces at lists.osgeo.org
Date: Fri, 1 Nov 2013 15:40:08
To: PostGIS Users Discussion<postgis-users at lists.osgeo.org>
Reply-To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] st_band with out-db raster data
On 1 November 2013 15:10, Dilley, Andrew-P57500 <Andrew.Dilley at gdc4s.com> wrote:
> From that thread,
> "We need to do away with the entire in-db and out-db notion and just return the pixel values."
> I guess this is what I mean. Should st_band be doing this?
I understand this is not easy to follow the thread and the comments
posted to the #2217 ticket. However, the conclusion you can draw from
those discussions is that the raster WKB format as well as
the default behaviour of basic API does not change -
PostGIS raster keeps to return server path
http://trac.osgeo.org/postgis/ticket/2217#comment:23
The WKB format is currently defined (version 0) is unable to properly
handle out-db raster bands for clients.
Hence, there is related ticket that adds extra parameter to override
default behaviour of the APIs
http://trac.osgeo.org/postgis/ticket/2222
I'm not a heavy user of out-db rasters, but I *perhaps* there are other APIs
like ST_Band, that should be updated according as ST_Binary has
been changed as result of the #2222 ticket.
Anyway, I'm just trying to explain you the current situation, but
I'll leave the decisions about API changes to Pierre and Bborie.
> (I'm admittedly very new to postgis so maybe this a stupid question).
IMO, no question is stupid.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
