[postgis-users] Grid of points inside Polygon
James David Smith
james.david.smith at gmail.com
Fri Nov 15 05:32:13 PST 2013
Hey.
Yes, it's done. Was just getting some lunch! :-)
select count(*) from lines_for_each_road
Result = 187033
I have also just ran 'VACUUM ANALYZE' on the tables
'lines_for_each_road' as well as the table 'all_lines'
I also can confirm that I have ran the following commands:
CREATE INDEX all_lines_index ON all_lines USING GIST ( the_geom )
CREATE INDEX ukmajrdbuffer_index ON ukmajrdbuffer USING GIST (geom);
Should we now uncomment this line from the previous query?
" SELECT row_number() over() AS id--,* "
Thanks again Remi,
James
On 15 November 2013 13:14, Rémi Cura <remi.cura at gmail.com> wrote:
> Also if you do have indexes,
> can you run a "VACUUM ANALYZE", so that the indexes will be used?
> Cheers,
> Rémi-C
> 2013/11/15 Rémi Cura <remi.cura at gmail.com>
>> It should be finished by now,
>> can you check you have geom indexes on :
>> "ukmajrdbuffer.geom" and "all_lines.the_geom"
>> How many geoms do you have in "ukmajrdbuffer"?
>> Cheers,
>> Rémi-C
>>> Hey Sandro,
>>> Thanks for this, it is at least twice faster =)
>>> Cheers,
>>> Rémi-C
>>> 2013/11/15 James David Smith <james.david.smith at gmail.com>
>>>> Thanks both. Geometries now fixed.
>>>> The query 'CREATE TABLE lines_for_each_road....' has now been set
>>>> running. Will report back when it's done. I suspect it may take a
>>>> while!
>>>> James
>>>> On 15 November 2013 11:03, Sandro Santilli <strk at keybit.net> wrote:
>>>> > On Fri, Nov 15, 2013 at 11:50:42AM +0100, Rémi Cura wrote:
>>>> >> Yep, maybe something like
>>>> >> UPDATE ukmajrdbuffer SET the_geom = ST_MakeValid(the_geom)
>>>> >> WHERE ST_IsValid(the_geom) = FALSE
>>>> > ST_MakeValid internally checks for ST_IsValid, so no need
>>>> > to add the condition (which would run the test twice).
>>>> > --strk;
>>>> > _______________________________________________
>>>> > postgis-users mailing list
>>>> > postgis-users at lists.osgeo.org
>>>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
