[postgis-users] Grid of points inside Polygon
Rémi Cura remi.cura at gmail.com
Fri Nov 15 05:43:17 PST 2013
Good !
Something is strange with the result,
you get only 190k lines intersecting road buffer,
it is very few , I expected at least 10times this!
How many time took this computing by the way?
How many road buffer geom do you have ? (select count(*) from ukmajrdbuffer
Cheers,
Rémi-C
2013/11/15 James David Smith <james.david.smith at gmail.com>
> Hey.
> Yes, it's done. Was just getting some lunch! :-)
> select count(*) from lines_for_each_road
> Result = 187033
> I have also just ran 'VACUUM ANALYZE' on the tables
> 'lines_for_each_road' as well as the table 'all_lines'
> I also can confirm that I have ran the following commands:
> CREATE INDEX all_lines_index ON all_lines USING GIST ( the_geom )
> CREATE INDEX ukmajrdbuffer_index ON ukmajrdbuffer USING GIST (geom);
> Should we now uncomment this line from the previous query?
> "  SELECT row_number() over() AS id--,*  "
> Thanks again Remi,
> James
> On 15 November 2013 13:14, Rémi Cura <remi.cura at gmail.com> wrote:
> > Also if you do have indexes,
> > can you run a "VACUUM ANALYZE", so that the indexes will be used?
> > Cheers,
> > Rémi-C
> > 2013/11/15 Rémi Cura <remi.cura at gmail.com>
> >> It should be finished by now,
> >> can you check you have geom indexes on :
> >> "ukmajrdbuffer.geom" and  "all_lines.the_geom"
> >> How many geoms do you have in "ukmajrdbuffer"?
> >> Cheers,
> >> Rémi-C
> >>> Hey Sandro,
> >>> Thanks for this, it is at least twice faster =)
> >>> Cheers,
> >>> Rémi-C
> >>>> Thanks both. Geometries now fixed.
> >>>> The query 'CREATE TABLE lines_for_each_road....' has now been set
> >>>> running. Will report back when it's done. I suspect it may take a
> >>>> while!
> >>>> James
> >>>> On 15 November 2013 11:03, Sandro Santilli <strk at keybit.net> wrote:
> >>>> > On Fri, Nov 15, 2013 at 11:50:42AM +0100, Rémi Cura wrote:
> >>>> >> Yep, maybe something like
> >>>> >> UPDATE ukmajrdbuffer SET the_geom = ST_MakeValid(the_geom)
> >>>> >> WHERE ST_IsValid(the_geom) = FALSE
> >>>> > ST_MakeValid internally checks for ST_IsValid, so no need
> >>>> > to add the condition (which would run the test twice).
> >>>> > --strk;
> >>>> > _______________________________________________
> >>>> > postgis-users mailing list
> >>>> > postgis-users at lists.osgeo.org
> >>>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131115/39b1d9fb/attachment.html>
