[postgis-users] missing libxml2.la file when compiling PostGIS 2.1.1 from Source on Ubuntu 12.04
Mike Toews
mwtoews at gmail.com
Mon Nov 18 18:59:19 PST 2013
I was able to successfully build this on a 32-bit virtual machine a week
ago:
http://trac.osgeo.org/postgis/wiki/UsersWikiPostGIS21Ubuntu1204src
I'm not sure what the problem is for your situation, but perhaps you
configured the build differently. Try also recompiling GDAL.
You should have e.g. /usr/lib/i386-linux-gnu/libxml2.la from libxml2-dev as
shown here
http://packages.ubuntu.com/precise/i386/libxml2-dev/filelist
so maybe try:
sudo apt-get install --reinstall libxml2-dev
-Mike
On 19 Nov 2013 08:22, "Paolo Corti" <pcorti at gmail.com> wrote:
> Hi list
> When compiling PostGIS 2.1.1 I am getting the following error on my
> Ubuntu 12.04 box (when making):
> make[2]: Entering directory `/opt/gis/postgis/postgis-2.1.1/raster/loader'
> gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I../rt_core
> -I../../liblwgeom -I/usr/local/include -I/usr/include -c
> raster2pgsql.c
> /bin/bash ../../libtool --mode=link gcc -g -O2 -fPIC -DPIC -Wall
> -Wmissing-prototypes -I../rt_core -I../../liblwgeom
> -I/usr/local/include -I/usr/include ../rt_core/librtcore.a
> raster2pgsql.o ../../liblwgeom/liblwgeom.la -L/usr/local/lib -lgdal
> -L/usr/lib -lgeos_c -lc -lm -o raster2pgsql
> libtool: link: cannot find the library
> `/usr/lib/i386-linux-gnu/libxml2.la' or unhandled argument
> make[2]: *** [raster2pgsql] Error 1
> make[2]: Leaving directory `/opt/gis/postgis/postgis-2.1.1/raster/loader'
> make[1]: *** [rtloader] Error 2
> make[1]: Leaving directory `/opt/gis/postgis/postgis-2.1.1/raster'
> Effectively, the libxml2.la file is not on my computer.
> The libxml2 and libxml2-dev versions I am using is the one from ubuntu
> precise repository:
> 2.8.0+dfsg1-5ubuntu2.2~precise1
> any hint? Upgrading libxml2?
> Note: I can successfully compile PostGIS 2.0.2 in the same machine.
> thanks a lot
> p
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131119/0fac2453/attachment.html>
