[postgis-users] operator && return errors where st_overlaps or st_intersects does not
Huub Fleuren huub.fleuren at geodan.nl
Fri Nov 22 02:28:45 PST 2013
Ha Sandro
Yes, you have to run make install, and run it _before_
loading the scripts upgrader.
oke well, please update the manual to discribe upgrade (SOFT and HARD)
a little more in the PostGIS manual.
surprized me that after
make clean
make
there were no upgrade sql-upgrade scripts at all.
nothing said i was up to date to anything.
I tried everything on a second installation that has the same
configuration. In the correct order this time, allthough also here the
postgis_upgrade_15_minor.sql script was not there.
The error still is there.
I wait for 1.5.9 release. And try again.
Maybe upgrade alltogether to PostGIS2?  Is that memory leak you
mentioned closed in PostGIS2?
Regards,
Huub
**E huub.fleuren at geodan.nl <mailto:huub.fleuren at geodan.nl>
<http://www.geodan.nl/disclaimer>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131122/bbd55c76/attachment.html>
