[postgis-users] Qgis/Postgis : impossible to open a project
Nicolas Ribot
nicolas.ribot at gmail.com
Fri Nov 22 03:03:45 PST 2013
The actual pg_hba.conf file is in the C:\Program
Files\PostgreSQL\9.1\data folder
Nicolas
On 22 November 2013 11:50, laurent <lcelati at latitude-geosystems.com> wrote:
> Hello,
> So. In the folder C:\Program Files\PostgreSQL\9.1\share, i have a file
> called "pg_hba.conf.sample".
> Please find below the raw sentences :
> # IPv4 local connections:
> host all all 127.0.0.1/32 @authmethod@
> # IPv6 local connections:
> host all all ::1/128 @authmethod@
> -> I tried to change these sentences to:
> host all all 192.167.40.92 trust
> 192.167.40.92 is the station 's ip hosting the postgresql server.
> 1/But the allow connection does not work. I can't open pg data from another
> station.
> 2/Why my file called "pg_hba.conf.sample". Why there is the extension
> .sample? The file extension should be .sample, .txt, .conf?
> Could you throw light for me?
> In advance, thank you.Regards.
> View this message in context: http://postgis.17.x6.nabble.com/Qgis-Postgis-impossible-to-open-a-project-tp5003712p5004935.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
