[postgis-users] Qgis/Postgis : impossible to open a project
laurent lcelati at latitude-geosystems.com
Fri Nov 22 02:50:48 PST 2013
Hello,
So. In the folder C:\Program Files\PostgreSQL\9.1\share, i have a file
called "pg_hba.conf.sample".
Please find below the raw sentences :
# IPv4 local connections:
host    all             all             127.0.0.1/32            @authmethod@
# IPv6 local connections:
host    all             all             ::1/128                 @authmethod@
-> I tried to change these sentences to:
host    all             all             192.167.40.92           trust
192.167.40.92 is the station 's ip hosting the postgresql server.
1/But the allow connection does not work. I can't open pg data from another
station.
2/Why my file called  "pg_hba.conf.sample". Why there is the extension
.sample? The file extension should be .sample, .txt, .conf?
Could you throw light for me?
In advance, thank you.Regards.
View this message in context: http://postgis.17.x6.nabble.com/Qgis-Postgis-impossible-to-open-a-project-tp5003712p5004935.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
