[postgis-users] operator && return errors where st_overlaps or st_intersects does not
Huub Fleuren
huub.fleuren at geodan.nl
Fri Nov 22 03:46:03 PST 2013
> Could you please file a ticket on http://trac.osgeo.org/postgis/ ?
i 'll try that, and the patch to the ticket
> The upgrade scripts are created under different
> subdirectories in the build tree. Of course you
> won't see them in the system directories until
> you "make install".
> $ make install > install.log && grep upgrade install.log
Great hint! (good for the updated manual :-)
After running the 15 upgrade the error still exists
Regards, Huub
*Geodan*
Buitenhaven 27-A
5211 TP 's-Hertogenbosch (NL)
T +31 (0)73 - 692 5151
E huub.fleuren at geodan.nl <mailto:huub.fleuren at geodan.nl>
www.geodan.nl <http://www.geodan.nl/> | disclaimer
<http://www.geodan.nl/disclaimer>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131122/daac5770/attachment.html>
