[postgis-users] Qgis/Postgis : impossible to open a project
Morten Sickel morten at sickel.net
Fri Nov 22 07:27:42 PST 2013
Hmmm ... everything looks fine.  What kind of messages do you get when you
restart postgres? You are running the postgres server on the same machine
as you are running qgis on?
And by the way, the error message you showed us, means that qgis is not
able to find postgres at all, this usually means that either the port or
host name is wrong, the server is blocked by a firewall or the server is
down. You would have gotten another message if it tried to connect but was
refused for some reason.
Sorry not being able to be any more specific.
Morten
laurent skrev:
> I paste below the usefull sentences from  my postgresql.conf:
> listen_addresses = '*'		# what IP address(es) to listen on;
> 					# comma-separated list of addresses;
> 					# defaults to 'localhost', '*' = all
> 					# (change requires restart)
> port = 5432				# (change requires restart)
> max_connections = 100			# (change requires restart)
> It looks '*' meaning : all addresses are listened by defaults...
> Regards.
> http://postgis.17.x6.nabble.com/Qgis-Postgis-impossible-to-open-a-project-tp5003712p5004945.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
